4th gen corner lamps?!
Old Nov 23, 2002 | 02:39 PM
Amnesia's Avatar
Default 4th gen corner lamps?!
Ok, I can't seem to figure out how to get my corner lamps out so I can replace the bulbs. I did a search and found one thread that didn't help me at all, so I need to know what to do to get them out. I took out the top screw, unplugged it, and there seems to be one last screw on the lower portion, and I can't get it out at all! How should I go about this? Thanks!
-Sam
Old Nov 23, 2002 | 03:10 PM
Diegolude's Avatar
Default Re: 4th gen corner lamps?! (Amnesia)
I have the same Question, My Preludes Right Corner Light is Out, and I need to Replace them
Old Nov 23, 2002 | 03:37 PM
phildeez's Avatar
Default Re: 4th gen corner lamps?! (Diegolude)
if i remember correctly there is a screw right above the light by the fender. there is a hole in the metal to get to the screw.
Old Nov 23, 2002 | 04:11 PM
LudEcrous's Avatar
Default Re: 4th gen corner lamps?! (phildeez)
yup that's right...there is a hole above the headlight by the corner light that holds the screw. after you take that screw out you just have to yank forward(you might have to use some force) on the corner light and it will come out.
Old Nov 23, 2002 | 08:02 PM
Amnesia's Avatar
Default Re: 4th gen corner lamps?! (LudEcrous)
Hmm...Maybe I just didn't pull enough, guess I'm scared of hurting my baby! But it seems like there's another screw on the bottom of it. I looked in my manual, and the absurdly small diagram seems to show another connector of some sort...Oh well, I'll try again tomorrow. Thanks again.
-Sam
Old Nov 24, 2002 | 06:27 AM
munscher's Avatar
Do these cornerlights just come on while the headlights are on? any other purpose?
Old Nov 24, 2002 | 11:20 AM
Diegolude's Avatar
purty?
Old Nov 24, 2002 | 11:58 AM
neRd's Avatar
just curious... what kinda corner lamps do you have?
Old Nov 24, 2002 | 12:04 PM
DeeJay's Avatar
New User
Default Re: 4th gen corner lamps?! (neRd)
There is a screw on top of it you need to take out. Then you just pull the lens out. The trick is to wedge a flathead betweeh the lens and the fender, be careful with your paint.
jjr_99prelude
Jan 9, 2008 12:54 PM
NSX4evr2006
Apr 17, 2006 04:52 PM
motegiracersi
Mar 17, 2004 07:41 AM
SiCkSrV
Mar 30, 2003 10:12 AM
Hippie
Nov 22, 2002 03:07 AM
