help please..... which map sensor do i use??
Old Nov 23, 2002 | 08:42 AM
I_love_my_Crx's Avatar
Default help please..... which map sensor do i use??
i have an 89 rex with a b18a and its been having problems....i took it to a shop and they told me that i need a map sensor along with other things but my question is which one do i use and is it okay to buy used....help will be greatly appreciated thanks
Old Nov 23, 2002 | 08:54 AM
zCivic's Avatar
Default Re: help please..... which map sensor do i use?? (I_love_my_Crx)
Any map sensor will work. As long as its on the firewall. DX, SI, or the LS will work. I say on the firewall because I know 92+ civics its built on the throttle body. Not sure if the 92-93 tegs are still on the fire wall or not. Buying used should be fine as long as it works. I have one off a teg if you need it. What other things did they say you needed?
Old Nov 23, 2002 | 08:57 AM
they say i need a distributor and a brake booster....
Old Nov 23, 2002 | 09:00 AM
zCivic's Avatar
Both I can understand. Dont have any xtras of those right now. The brake booster isn't bad to replace just have to crawl under the dash and adjusting it is a pain. The Diz is a breaze, could try junk yard only. What is wrong with the Diz did they say?
Old Nov 23, 2002 | 10:03 AM
Default Re: help please..... which map sensor do i use?? (zCivic)
yea...i got a new one from autozone...(i know it was a bad decision but it was cheap)...and it dosent work right... they said you cant set the time on it and i have had the same problem with two other distributors that i bought there...
Old Nov 23, 2002 | 10:15 AM
CimorelliCRX's Avatar
What cant you time? All you need to do is turn the distributor when the bolts are in to time it, every distributor you can time. I think anyway, i maybe wrong..
Old Nov 23, 2002 | 10:29 AM
Default Re: help please..... which map sensor do i use?? (CimorelliCRX)
cant fully set it...it is turned all the way and still not where it is supposed to be
Old Nov 23, 2002 | 11:14 AM
zCivic's Avatar
Did you take the timing belt off?? Think your not at TDC with the cams and bottom end. You can adj on the Diz +/- around 8% pretty sure. But if your off a cam tooth its 18% each tooth. If they cann't adj to get it in time and you removed the timing belt. I bet that the true problem. If this is it I would fire the mechanic and hire a new one.
Old Nov 30, 2002 | 11:24 AM
found out what was wrong....it was my timing belt....it was off time and i replaced the dizz and the brake booster but now my brake light goes on....
woojdm
Jun 9, 2009 08:54 PM
reddysol
Sep 8, 2007 10:57 AM
ALL MOTOR DA
Jun 8, 2006 05:58 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
specktur
Mar 30, 2004 05:31 AM
