Tranny problems: hard to shift, what's wrong?
Old Nov 23, 2002 | 08:14 AM
Brewer's Avatar
Default Tranny problems: hard to shift, what's wrong?
First off, I've got a '93 CX with a B16A3.
The problem just started yesterday. Didn't seem gradual, just all of the sudden. When driving the car it's very difficult to shift gears, almost like the clutch isn't fully disengaging. But I don't think the clutch is the problem, it appears to be working exactly as it should. What else could be wrong?
Thanks
[Modified by BrewerHatch, 11:25 AM 11/23/2002]
Old Nov 23, 2002 | 08:18 AM
Brewer's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (BrewerHatch)
Pic just to get this thread noticed
Old Nov 23, 2002 | 09:03 AM
edgeridercr15's Avatar
Same type of thing happend to me. My pressure plate clips broke. The clutch doesn't feel different, but shifting is almost like you shifting without the clutch. I would have the pressure plate checked out. It happend to me twice.
Old Nov 23, 2002 | 09:07 AM
Clayton's Avatar
H-T Administrator
25 Year Member
This is just an odea for you, and I am by no means saying that this will solve your problems, but when was the last time you had the tranny oil changed? I know on my wife's CRX when I changed the oil in it made the tranny feel like new again, although the hard shifting coming all at once doesn't sound like this is the problem. I'd have to say anything that comes on so suddenly makes me think of some sort of mechanical failure. Like broken fingers on the pressure plate, or something of that nature...
Clayton
Old Nov 23, 2002 | 10:05 AM
M-EJ1's Avatar
Check the clutch master cylinder before you do anything else. Not saying for sure that's what it is, but my car acted like this when my hydraulic clutch fluid was low. And it happened out of the blue all of the sudden, it wasn't gradual. However, when it happened to me, my clutch when almost to the floor before disengaging.
Old Nov 23, 2002 | 10:19 AM
h82lose2vw's's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (matt-eg)
how many miles are on the trans .... it could be the synchros
Old Nov 23, 2002 | 10:28 AM
blackANESE's Avatar
Old Nov 23, 2002 | 01:05 PM
BlackDeuceCoupe's Avatar
HT White Ops
...When driving the car it's very difficult to shift gears, almost like the clutch isn't fully disengaging...
If the clutch wasn't disengaging, you wouldn't be able to put it into gear, from a dead stop, without a lot grinding. Is this a problem too?
Old Nov 23, 2002 | 01:29 PM
Brewer's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (h82lose2vw's)
~45k... I doubt it's the synchros
Old Nov 23, 2002 | 02:05 PM
Brewer's Avatar
Sitting still with the car off it shifts like a dream. Car running sitting still, no grinds. Driving down the road, pretty easy to get out of gear, hard to get into gear. I pretty much just have to "rev-match" or whatever you wanna call it.
Old Nov 23, 2002 | 02:22 PM
HT White Ops
Sitting still...shifts like a dream. Car running...no grinds. Driving down the road...hard to get into gear... pretty much just have to "rev-match".
Well, I would say you don't have any oil in your tranny, or it's extremely low. When is the last time you changed/checked it ???
Old Nov 23, 2002 | 02:34 PM
fakemike's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (BlackDeuceCoupe)
if your tranny was losing oil I think you would be able to tell by spots in your driveway.
Old Nov 23, 2002 | 02:54 PM
HT White Ops
Default Re: Tranny problems: hard to shift, what's wrong? (fakemike)
I'm talking about his tranny, not mine...
Old Nov 23, 2002 | 04:00 PM
t0p_sh0tta's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (jspecsirhatch)
Lucky you, my pressure plate snapped in 3 places.
Old Nov 24, 2002 | 06:38 AM
Brewer's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (REVOEVOM)
If the clutch needs to be replaced, how difficult is that? Should I do it myself or get someone else to?
Old Nov 24, 2002 | 06:57 AM
Ya@inlinePRO's Avatar
my boy and i replaced his clutch and flywheel while his block was sitting outside before the swap, it was annoying when it was outside, so if the block is inside the chasis, i'm sure it would suck, i don't think it was HARD, but it was annoying good luck
Old Nov 24, 2002 | 09:30 AM
96HatchB18's Avatar
My guess would definitely be the springs on the pressure plate snapped off. I had the same thing happen to me. I would get it fixed ASAP...... I drove on it for a little and I scored and burnt up the flywheel so bad that it needed to be completely replaced.
Old Nov 24, 2002 | 11:28 AM
HT White Ops
It's a bish. Checking the oil is easier. Have you done that yet?!?!?!?!?
Old Nov 24, 2002 | 11:35 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Tranny problems: hard to shift, what's wrong? (96HatchB18)
I'll say that I'm 90% sure that a spring or springs in the clutch DISC have popped out.
What happens is a spring will pop out and get tossed around in there and when it binds up between the disc and P.P or flywheel then that's when you cannot shift. Once it becomes dislodged then it will shift like normal again, thus giving you the unpredictability factor.
I've seen a number of stockie and Clutch Masters clutches do this - sometimes the disc will have shitloads of wear left but once the springs pop out it's useless.
I'd say you probably need a clutch.
Check the tranny fluid, but usually if you're low it will shift okay but 5th will be messed up because it's the last gear to get oil. It would even pop out if you're low on fluid.
Old Nov 24, 2002 | 11:39 AM
JDMSpo0nS0L's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (B18C5-EH2)
i think.. it could be oil.. but if you checked it.. then its ko0..
that happened to me too.. from downshifting.. and racing a stock clutch some guy told me that (autozone i dont think he knows what he is talking about).. if htere is no oil in the tranny you have a leak.. if you taken motor out.. and right back in.. check axles if there all the way in peace
Old Nov 24, 2002 | 02:24 PM
Brewer's Avatar
Tom,
Shifting is in no way undpredictable. It's just hars to shift. Like shifting without the clutch. Also, when starting from a stop the clutch chatters a whole lot, which it NEVER did before.
OT: my Carsound cat has now self-destructed after only a month!
Old Nov 24, 2002 | 04:15 PM
vw-honda-hatches's Avatar
i was road testing a older integra the other day (i am a acura tech) and this exact thing happened to me. with the clutch all the way depressed, and the car would still move. Replace the clutch and boom, a nice missing clutch spring....everything is cool know, after there hefty bill
Old Nov 24, 2002 | 04:22 PM
MugenGTR's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (vw-honda-hatches)
mines straight out hard to shift, whether the car is moving, on, off, watever, it's jus HARD!
S2KBAR
Dec 18, 2006 09:39 PM
Asway
Jan 31, 2005 09:14 PM
a_new_honda_owner
Mar 17, 2004 05:21 AM
fengxzhang
Feb 22, 2004 06:09 PM
Striker
Nov 26, 2001 03:46 PM
