Problem - Broken Rear Strut bolt 5g accord
Old Nov 23, 2002 | 08:02 AM
EndlEEsss's Avatar
Default Problem - Broken Rear Strut bolt 5g accord
I actually broke the rear lower strut bolt on my 96 accord.
Do you guys know where i can get that bolt drilled out in SoCal?
Also, is the nut welded on the rear strut?
Please help
Thanks
Old Nov 23, 2002 | 10:33 AM
Stew Pidasso's Avatar
Default Re: Problem - Broken Rear Strut bolt 5g accord (TweakMeUp)
Yes that nut is welded on. I broke that same bolt before on my 4th gen. I had to basically torch it out and replace the bushing. The nut on the strut was also cut off and replaced. It will be a major PITA. Order the new bolt, bushing and get a nut from Honda and then take it to a local mechanic. It will probably take them lees than an hour to do and will save you many hours of grief & split knuckles. Come to think of it, I think I broke that on my 5th gen also...
Old Nov 25, 2002 | 06:30 AM
EndlEEsss's Avatar
Default Re: Problem - Broken Rear Strut bolt 5g accord (Stew Pidasso)
man, i been to 4 different auto repair shops and they will not do the work.
any help from SoCal area?
Old Nov 25, 2002 | 07:29 AM
sparknblaze's Avatar
A friend of mine worked at midas and they did that kind of work. I don't know because I'm on the east coast but I would think they have Midas's over there in Cali. Go somewhere where they do exhaust work & suspension and they will more then likely be able to do it. I have the same problem right now with my 5th gen wagon and I'm trying to put the NEX adjustable coilovers on the rear but need to catch up with my Midas friend.
Old Nov 25, 2002 | 07:31 AM
KGAccord's Avatar
Not hard, use an acetelyn torch to cut the struts. The hard part is salvaging the bushings, which since you already know your fucked, go and buy new ones from Honda.
Drilling is very tough with that type of a bolt even with a Titanium tip, take my word for it.
Old Nov 25, 2002 | 08:54 AM
Howitt's Avatar
Default Re: Problem - Broken Rear Strut bolt 5g accord (KGAccord)
same thing happened to me, I cut the bolt off, tore out the bushing and ghetto rigged it using a new bushing which I cut the metal outside off of it and just used a nut that wasnt welded and its been fine for about 2 years now I check on it from time to time
[Modified by Howitt, 5:54 PM 11/25/2002]
Old Nov 25, 2002 | 09:01 AM
urbanlegend21's Avatar
New User
Default Re: Problem - Broken Rear Strut bolt 5g accord (Howitt)
take it to a machine shop and they will drill it out for you, I don't know how many bolts we have broken on the farm and just tapped out with a hand drill
Old Nov 25, 2002 | 09:29 AM
Accord94DX's Avatar
Default Re: Problem - Broken Rear Strut bolt 5g accord (urbanlegend21)
the honda dealership i work at has done those jobs before. Cost ~80 bucks. Then again im in MN so whatever....
Old Nov 28, 2002 | 03:04 PM
EndlEEsss's Avatar
Default Re: Problem - Broken Rear Strut bolt 5g accord (Accord94DX)
Thanks for all the advice.
Old Jul 1, 2019 | 11:32 AM
Howard Roark's Avatar
Please help
Thanks
Same problem snapped the bolt, I fixed it...
Pulled off the whole nuckle drilled around bushing rubber popped out old one,the. Chizzle out the ring went to parts place got moog part #k9443
15$ hammer it in with wood, or block of metal, evenly, finished
solfire
Dec 3, 2010 12:51 PM
butchgibson
Mar 4, 2006 03:26 PM
FREAKquency04
May 18, 2004 06:57 PM
99sonicbluegsr
Mar 1, 2004 07:15 AM
