Pictures of GM 3 Bar Map Senor Installed...???
Looking to see how this goes...i found the wiring instructions, but does this thing fit the original map sensor location?? or do you have to rig it up like the jdm b16 map sensor with a lil hose off the intake manifold..??
so post away with those pictures!!!
thanks,
chris
so post away with those pictures!!!thanks,
chris
you need a plate that sits on the throttlebody with a nipple. take vacuum from that nipple the the vacuum nipple on the gm sensor
i dont know where to get the plates though anyone???
why not just leave the stock map on the throttle body to plug that hole and run a vacuum line off the intake manifold to the map sensor?
thank you for the imput
chris
