What are the best rods for N/A reving to 9000 limit bottom end.... fully built
Old Nov 23, 2002 | 07:38 AM
HotWheelz's Avatar
Default What are the best rods for N/A reving to 9000 limit bottom end.... fully built
I was thinking about the CROWER I beams not the econobillet.
some people say "EAGLE ESP"
Some people say "probe rods"
some people say "Saenz"
i'm sure their's others...
what are your opinions and suggestions... when i get a good choice i'm ordering them..
full rotating mass will be balanced, type-S pistons, torqueplated block line bore frm sleves over, rods balanced with crank and motion assembly, no shafts, pro-drive oil pump.. new rings all seals bearings and possibly edge crank if needed...
block is closed deck...
no underdrive pulley will retain harmonic balancer and extremly lightweight alum flywheel...
also h23 tensioner assembly.
thanx guys! your comments are welcommed..
and no i'm not going stock rod... not even shot peened... I want reliabitly.. or should i say GREATER reliability.
any information would be graetly appreciated.
Old Nov 23, 2002 | 07:43 AM
satan_srv's Avatar
Default Re: What are the best rods for N/A reving to 9000 limit bottom end.... fully built (HotWheelz-turboh
I think even aftermarket rods aren't enough for 9000rpms in an H22a. Like I'm destroking to 88mm and I think 8500 is my max. Remember I broke my CRANK, so there's something to think about
papasito
Jun 25, 2009 12:49 AM
lunatics209
Jun 12, 2008 01:38 AM
Honda_Fanatic
Apr 23, 2008 07:25 AM
Darkane
Oct 12, 2005 12:37 PM
DEMNTD1
17
Oct 10, 2005 08:47 PM
