How should I run my VAC lines?
Old Nov 22, 2002 | 10:23 PM
TheIntegraGuy's Avatar
Default How should I run my VAC lines?
Right now, I have a vac line to a boost gauge all by itself. I also have the WG acutator T'd off with the BOV going to it's own source. BTW, a MBC is on there as well.
The problem is, no matter which way I turn the MBC, it never boosts any more or less than 7psi? Boost leak? I'm not sure because it boosts fine and it holds boost all the way through. Maybe sharing the MBC line and the BOV line effects it? I'm not sure..
Anyways, I was wondering if I should run my BOV line and T it with my boost gauge line and just run a vac line from the acutator, through the MBC and to it's own source...
What do you guys suggest? Thanks.
Old Nov 23, 2002 | 12:08 AM
ninesecrx's Avatar
Default Re: How should I run my VAC lines? (Esone3)
I think you should try what you just said.
Old Nov 23, 2002 | 07:43 AM
Default Re: How should I run my VAC lines? (ninesecrx)
Cool..anyone else think differently?
mikej94civex
Apr 10, 2010 09:09 AM
bads2k
Nov 26, 2009 01:38 PM
seeeya04
Dec 1, 2005 06:40 AM
LSEGHATCH
Oct 29, 2005 04:25 PM
Tofurky
Jul 9, 2002 11:56 AM
