Breather Filter or Vacum tube? Which is better?
Old Nov 22, 2002 | 10:05 PM
variable's Avatar
Default Breather Filter or Vacum tube? Which is better?
I am thinking about getting a intake for my d16z6 and using a breather filter insted of the vacum tube...some of my friends say i should stick with the vacum tube, some say i should use the bf. Whats the +/- for each option?
Old Nov 22, 2002 | 10:12 PM
TheKidd's Avatar
Default Re: Breather Filter or Vacum tube? Which is better? (variable)
The breather filter is fine only if you change it VERY often. The vacuum tube creates a cycle with the hot air being pulled away from the valve cover.
Old Nov 22, 2002 | 10:15 PM
Hatch-E's Avatar
Default Re: Breather Filter or Vacum tube? Which is better? (TheKidd)
if you want, you can route a catch can for the blow-by. but for the thread, stick with the v/t
themadtuner
May 1, 2008 01:05 PM
92civicx
Oct 17, 2007 06:27 PM
65coupe
Jan 15, 2005 04:51 AM
Jay J
24
Oct 12, 2003 08:57 AM
