fuel tank pressure sensor
Old Nov 22, 2002 | 08:06 PM
KiLLa CaM 06's Avatar
Default fuel tank pressure sensor
I have a b16 in my 97 hatchback w/p73 ecu. its throwing a cel 91. fuel tank pressure sensor too high or low. can it be the fpr. need help so i can get rid of the cel. thanks
Old Nov 23, 2002 | 12:54 AM
b19coupe's Avatar
Default Re: fuel tank pressure sensor (olskodumie)
It is not fuel pressure related. The FTP sensor measures pressure in the fuel tank and is used in OBD2 cars to check the Evap. system for leaks and proper operation.
Old Nov 29, 2002 | 04:07 PM
RoaringTurtle's Avatar
New User
Default Re: fuel tank pressure sensor (b19coupe)
i have this same problem
although it only comes on when its a cold start
if i reset the ecu and then start it back up
it doesnt come on
anybody have any ideas?
Old Dec 27, 2002 | 12:12 PM
DR. ON POINT's Avatar
Banned
Default Re: fuel tank pressure sensor (RoaringTurtle)
I am having the same problem.......... anyone have any ideas
Old Dec 27, 2002 | 12:27 PM
sgT's Avatar
sgT
you need to use a 96-97 ecu as any ecu 98+ will look for the ftp sensor
Old Dec 27, 2002 | 01:18 PM
HNRevHard's Avatar
Default Re: fuel tank pressure sensor (sgT)
Does any body know how to bypass this or anything to make this cel91 off?
Old May 16, 2005 | 05:15 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: fuel tank pressure sensor (HNRevHard)
what the fps for? that why my gas lite dont turn on?
diagnostic
Sep 14, 2006 05:44 PM
oem
Mar 21, 2005 10:42 PM
eskp1
Jul 9, 2004 05:33 AM
