Integra 1.8L
Old Nov 22, 2002 | 08:06 PM
IntegraBoy04's Avatar
Default Integra 1.8L
I have a 99 Integra with a 1.8L non-vtec engine. What would be a good motor swap for it, or is it good like it is, and just fix that one up?
Old Nov 22, 2002 | 08:07 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Integra 1.8L (IntegraBoy04)
Keep your b18b...Always work with what you have.
Old Nov 22, 2002 | 08:22 PM
Pat's Avatar
Pat
Default Re: Integra 1.8L (Arturbo)
Your in the FI forum so I think most people would recommend that you turbo that b18b, like I am going to!!
Old Nov 22, 2002 | 08:25 PM
sweet's Avatar
Default Re: Integra 1.8L (Pat)
you could make it simple and hang on to the B18B then add a turbo system with Hondata. the proper turbo setup with good tuning will yield a nice power package, and the non-vtec cams are even easier to tune than the vtec ones with low and high lobes.
Old Nov 22, 2002 | 08:26 PM
johnisenglish's Avatar
Ditto
Old Nov 22, 2002 | 08:38 PM
SIK IN DA HED's Avatar
New User
Default Re: Integra 1.8L (johnisenglish)
keep it and slap a turbo kit on it.
Old Nov 22, 2002 | 08:41 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Integra 1.8L (dlplayboy)
Ls dyno, rev-hard turbo kit, Hondata, 550cc, and 100% stock motor @ 12psi...
art
Old Nov 22, 2002 | 10:10 PM
TheShocker's Avatar
Old Nov 22, 2002 | 10:51 PM
pub's Avatar
pub
Default Re: Integra 1.8L (TheShocker)
Art! wow - good numbers. esp the tq.
Old Nov 22, 2002 | 10:55 PM
dbman96's Avatar
New User
Default Re: Integra 1.8L (pub)
That curve could have even held onto a good amount more torque at high revs - AF dips pretty low by redline... wow.
OT - does anyone know how the B20 cams compare to the B18? I recently switched from my busted GSR head to a stock B20 head (both on B20 block) and daaaayyum this thing feels like it just runs OUT of steam at around 6000. It still pulls under boost but you can tell it doesn't want to breath well up that high. Should I be putting my energy into trying to improve the B20 / LS head or should I fix that GSR head (or maybe should I be looking for a B16 head and mani to do even better???)
Old Nov 22, 2002 | 11:32 PM
Teg4e's Avatar
Respect for the B18b, woohooo!
You might have to boost a little more than a B18C1 to get the same hp numbers, but I think the internals can handle the same amount of power. No need for a swap.
Old Nov 23, 2002 | 02:36 AM
VaporTrail's Avatar
New User
art
Ah, that brings back some memories Good times...
Old Nov 23, 2002 | 02:43 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Integra 1.8L (VaporTrail)
It should, you tuned it.
Old Nov 23, 2002 | 07:19 AM
The Mole's Avatar
is that DIRep972's?
[Modified by The Mole, 11:20 AM 11/23/2002]
Old Nov 23, 2002 | 08:55 AM
VaporTrail's Avatar
New User
Default Re: Integra 1.8L (The Mole)
yup
Old Nov 24, 2002 | 07:29 AM
Ok, what would be the best kind of turbo to put on my car, and how much would it cost? Also, what kind of intake is the best (AEM or what)? And how much do good strut bars cost?
Old Nov 24, 2002 | 08:01 AM
Smashback's Avatar
Are you sure you're not some WRX driving newb just trying to harrass the real enthusiasts? Maybe you just don't know what forced induction is but it has nothing to do with strut bars. Intakes are a waste of money on NA cars, but even moreso on turbo cars since you can't use them
Old Nov 24, 2002 | 07:26 PM
Default Re: Integra 1.8L (Hatchblack)
No I have an Integra, and I am a newbie, and I was just wondering, so I thought you people would be nice enough to answer some of my questions, but of course, people always have to be dicks about something. I wast just wondering. And why can't you use an intake on a turbo?
Old Nov 24, 2002 | 07:35 PM
mos's Avatar
mos
They are nice. They did answer. The charge pipe usually has to be routed differently than with a n/a intake pipe.
Old Nov 24, 2002 | 07:48 PM
Quick 200k Mile Motor's Avatar
Default Re: Integra 1.8L (dbman96)
Check it out.. http://hybrid2.honda-perf.org/tech/b20/b20tech.html
Saved that link a while back. Im not sure how accurate hybrid was back then, and they never went on to part 2 of B20 Ballistics. Its like Turbo mag not continuing with their "Decked Block" article, and they even said there would be a Part 2.
Scroll down on that page, there is a chart with part#'s showing that the B20Z has different camshafts than a B18B.
Old Nov 24, 2002 | 08:02 PM
filetofit
Guest
Posts: n/a
Default Re: Integra 1.8L (mos)
Although I bet a cold air intake could be used as the post intercooler half of your charge piping for a diy setup.
Old Nov 27, 2002 | 09:45 PM
Default Re: Integra 1.8L (filetofit)
Ok none of this is making sense. So you still could put a cold air intake on it right? And what else would you have to put on it to make it work right? Would you have to install a new exhaust system? And what kind of exhaust system is a really good one?
Old Nov 27, 2002 | 09:59 PM
yellowsub's Avatar
You need to discover the greatness of the honda-tech archives.
Old Nov 27, 2002 | 10:28 PM
Evil EG's Avatar
Default Re: Integra 1.8L (yellowsub)
goto http://www.howstuffworks.com then look up turbo. Come ask some questions after that.
Old Nov 28, 2002 | 06:07 AM
GEN2TEG's Avatar
art
Have you had any problems running at that amount of boost with your stock internals?
