LS motor in my 97 del sol
Old Nov 22, 2002 | 04:19 PM
Superior2u23's Avatar
Default LS motor in my 97 del sol
What do you think about putting an acura LS motor in my 97 del sol?
Old Nov 22, 2002 | 04:29 PM
DaveSi's Avatar
Default Re: LS motor in my 97 del sol (Superior2u23)
Should be easy. Just curious why are you going with the LS?
Old Nov 22, 2002 | 04:39 PM
Default Re: LS motor in my 97 del sol (DaveSi)
the LS will give me about another 35-40 horsepower and more tourque. My first choice was a GSR but an LS is easier to get and much cheaper. It will have basically the same effect. [IMG][/IMG]
[Modified by Superior2u23, 1:46 AM 11/23/2002]
Old Nov 22, 2002 | 04:40 PM
Nameless RB26's Avatar
no.. not really.
But it's ok.
Old Nov 22, 2002 | 04:47 PM
Default Re: LS motor in my 97 del sol (Nameless)
are you a mechanic?
if you are do you know if i will have to make any changes when i make the swap...like no air conditioning or something along those lines
[Modified by Superior2u23, 1:50 AM 11/23/2002]
Old Nov 22, 2002 | 04:48 PM
yah definetely.
Do you know the most obvious differences between an LS motor and a a GSR motor?
Old Nov 22, 2002 | 04:51 PM
what
Old Nov 22, 2002 | 04:54 PM
DaveSi's Avatar
Most of the swaps I've done and or seen take out the A/C and power steering but if you still want it, it can be done. And an LS is not that similar to a GSR.
horsepower? vtec? Are you serious? I think an LS motor in any civic is a good thing though, don't get me wrong.
Old Nov 22, 2002 | 06:33 PM
Slopoke's Avatar
You can keep your AC if you use the AC mount from a DOHC vtec delsol. Then just bolt your stock civic AC compressor to that.
You can keep your powersteering also, but I've never had to do it, so Im not sure exactly how its done.
Old Nov 22, 2002 | 07:53 PM
mooseknuckle's Avatar
Default Re: LS motor in my 97 del sol (Slopoke)
i hope your gunna boost the LS...
z3n
Nov 21, 2006 04:01 AM
lsvsol
Nov 18, 2006 07:21 PM
98cwtypeR
Mar 1, 2004 01:11 AM
DELshow
Dec 14, 2003 09:21 AM
Farrell
May 22, 2002 02:49 AM
