installing tach need help
Old Nov 22, 2002 | 01:39 PM
Simple's Avatar
Default installing tach need help
well i finally got the bitch mounted... (autometer 5" w/shift light) and i need to run the wires, im good on all but the green (tach) wire, where can i tap into the harness to pick up the tach signal? ive got a 94 DX, i know its already pre wired, but where can i tap in? can i tap in somewhere on the cluster harness?
Old Nov 22, 2002 | 02:09 PM
gsrvx's Avatar
New User
Default Re: installing tach need help (Simple)
blue wire..should be near the driver side shock tower. you should see the test tach signal plug.
-Rod
eljah0426
Mar 14, 2011 05:59 PM
CLE
12
Oct 31, 2007 07:31 PM
Mikey3000
Sep 6, 2006 02:32 PM
92egmonkeyb
Dec 9, 2004 11:19 AM
92-LS-Civic
Sep 13, 2004 11:09 AM
