ITR Rods or Eagle Rods...Best setup for 11.5:1 IB Weisco Pistons?
Looking for reliability as well as saving some cash....Don't have the money to dish out for crowers or anything like that, but I'd like to have some lower end reliability. Rod to Rod the Eagles LOOK stronger than the ITR, but that's just because they are wide as hell. Please I'm open to your suggestions, these rods are basically priced the same. BTW I'll be running these with Toda B's so I'll only be making power till 8200 so at max I'd ever probably shift would be at 8700.
i didnt think you can run aftermarket pistons with stock honda rods
either honda/honda or aftermarket/aftermarket;
piston/rod combo
piston/rod combo
piston/rod combo
piston/rod combo
Using a stock honda rod would require boring the small end so that the aftermarket wrist pin floats in the rod, but at that point, I am not sure if there will be any bushing material left in the piston.
Go aftermarket.
hold the pin like stock does. I have used either method and there are no problems
with either.
You can do that, or you can just leave the clips out of the pistons and let the rod
with either.
with either.
Now how about aftermarket rods with Honda Pistons
.....i'd go with the eagle rods if they're the same price. Forged, right?
Kinda OT: why such low compression pistons? At least go 12:1...
11.5:1 and then a 2 layer headgasket so about 11.7:1. It was recommended to me since this is my daily driver. I didn't want to go too extreme. I'm basically looking for 195-200whp.
