Tach problem
Old Nov 22, 2002 | 10:00 AM
allmotr1.8's Avatar
Default Tach problem
My stock tach is reading 500 rpm's lower than it's suppose to at idle in my 91 si. So at idle it's at 0, car runs fine just need some assistance or help, thanks.
Old Nov 22, 2002 | 10:22 AM
unltdacc12's Avatar
Default Re: Tach problem (allmotr1.8)
I thought i was the only one.. mine is doin the same thing.. im curious to see if there are any remedies for this
Old Nov 22, 2002 | 10:36 AM
Urban Business
Guest
Posts: n/a
Default Re: Tach problem (unltdacc12)
stock tachs are rarely acurate
Old Nov 22, 2002 | 11:10 AM
Hondasaurs's Avatar
Default Re: Tach problem (TorteX)
True. i have an Auto Meter tach and it reads about 400 rpms higher than my stock tack
Old Nov 22, 2002 | 11:35 AM
Urban Business
Guest
Posts: n/a
Default Re: Tach problem (ZC_CRX)
yeppers, read any service manual. when adjusting idle step 1 "hook up a tach"
Old Nov 22, 2002 | 11:36 AM
nolimits's Avatar
They should be more accurate on idle, though! I've never had my gauges out so I'm not sure, but can the needle be pulled and reapplied in the correct position? I would imagine the rest of the calibration would be accurate.
Old Nov 22, 2002 | 11:49 AM
90da's Avatar
Default Re: Tach problem (00turbosi)
yes the needle can be pulled off. i accidentally moved my speedo needle, and you can either just turn it or pull it off altogether
Old Nov 22, 2002 | 02:51 PM
allmotr1.8's Avatar
I know the stock tach's aren't accurate, but it's been fine for 3 months, i was thinking it was the distributor or wiring from the swap, but just drove it and it's back to normal, wierd?
Civicman86
Jul 10, 2007 02:40 PM
AccordEX1991
Mar 11, 2007 01:16 PM
Spins
Apr 18, 2005 02:01 PM
vinuneuro
Mar 28, 2005 11:41 PM
KeithsDAteg
Aug 31, 2004 12:01 PM
