Honda Accord EGR valve...
Old Nov 22, 2002 | 05:10 AM
GencivicIII's Avatar
Default Honda Accord EGR valve...
I have a 96 Honda Accord that is giving me a check engine light. When they tested it, it was a bad EGR. I replaced the EGR valve and EGR solenoid, but the check engine light is still on. When I changed those parts out I reset me ECU. Anyone had this problem. Could it be a bad ECU?
Old Nov 22, 2002 | 05:29 AM
Desslok's Avatar
Default Re: Honda Accord EGR valve... (GencivicIII)
I would check the vaccuum going to the EGR.
Old Nov 22, 2002 | 05:34 AM
Default Re: Honda Accord EGR valve... (sp)
So it could be a clogged vacuum line. I will check on it.
Old Nov 22, 2002 | 12:46 PM
bill-71SS's Avatar
what code does it have
Old Nov 22, 2002 | 01:07 PM
Chiovnidca's Avatar
Default Re: Honda Accord EGR valve... (bill-71SS)
Old Nov 22, 2002 | 01:43 PM
carolinaACCORD's Avatar
make sure there is not a break in the wire to the ECU, from the EGR valve.
Old Nov 22, 2002 | 04:28 PM
Big Business
Guest
Posts: n/a
i thought OBD2 has a fully electrical egr and didn't have vacuum lines going to it...i could be wrong though
Old Nov 22, 2002 | 06:54 PM
scrubachu's Avatar
Default Re: Honda Accord EGR valve... (Foomanshu)
make sure it is plugged in.
Old Nov 22, 2002 | 09:40 PM
WhoNeedsVtec's Avatar
Default Re: Honda Accord EGR valve... (scrubachu)
Did you reset the ECU after you fixed what you thought was the problem?
batbrit
Aug 23, 2013 10:25 PM
jw 1
Jul 4, 2013 04:06 AM
yzracer
Oct 2, 2011 04:23 AM
Forrester
Aug 15, 2009 05:51 PM
GVERMILLION
Jan 19, 2003 01:39 PM
