Help!!Bent valves??
Old Nov 21, 2002 | 06:27 PM
SuperTeg95's Avatar
Default Help!!Bent valves??
Well I went to the drag strip and had a horrible night. FIrst off I had a big problem getting traction. Then to make matters worse I shift from 3rd to 2nd and now the car won't idle . It drives fine and has a very small skip in it. The more I drive it the worse the skip gets. Anyway I checked all the plugs and none of them were bent or broken. The only other thing I can think of is jumped timing. ANyone else got any suggestions? BTW, I havent had a chance to do a compression test cause it's late and my tools are at work. I will check tomorrow. later.
My best run was crappy cause it spun ALOT. I ran an 8.33 @ 90mph!!!
Bad E.T. Good MPH
[Modified by SuperTeg95, 3:29 AM 11/22/2002]
Old Nov 22, 2002 | 02:09 AM
Trixie's Avatar
Default Re: Help!!Bent valves?? (SuperTeg95)
Coming from what I have heard and seen before........... you more than likely did bend your valves. They turn out to look like little short-shifters.
Old Nov 22, 2002 | 02:14 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Help!!Bent valves?? (Trixie)
Do a leak down test.
Old Nov 22, 2002 | 07:27 AM
FOrSfEd's Avatar
Default Re: Help!!Bent valves?? (Arturbo)
Yeah a leak down should tellyou what is wrong and if there is a bent valve.
Lee
Old Nov 22, 2002 | 08:26 AM
earl's Avatar
Default Re: Help!!Bent valves?? (ALLsh0w)
Talked to Nick this morning and he did bend valves. He's looking for a new head for a quick repair. Anyone?
Old Nov 22, 2002 | 12:40 PM
TeStUdO's Avatar
Default Re: Help!!Bent valves?? (earl)
its alot cheaper if you take the head off yourself and just take it directly to a machine shop to grind down the valves and do the valve seats. how many did you bend?
Old Nov 22, 2002 | 04:41 PM
SuperTeg95's Avatar
Default Re: Help!!Bent valves?? (00si5)
I don't know exactly how many I bent but cyl. 1 and 4 are shot. I know it would probably be cheaper to take it to a shop, but I don't have any down time (2-3weeks) to do that so if anyone has one for a B18c then let me know. Thanks Earl for the help .
Dark_Teg
25
Oct 11, 2009 11:05 AM
gsrvx
Sep 30, 2006 09:50 PM
-Todd-
Oct 14, 2005 06:46 PM
Layziebtnh055
May 12, 2004 07:06 AM
311
Jan 17, 2003 08:29 PM
