Simple Engine Question!?
Old Nov 21, 2002 | 02:26 PM
SIRBUSH's Avatar
Default Simple Engine Question!?
Will a B16A2 go into a 91 civic hatch SI
Thanks
Old Nov 21, 2002 | 02:33 PM
Flexmyrex's Avatar
Default Re: Simple Engine Question!? (SIRBUSH)
yes any b series will work as long as you use a cable transmission. unless you want to convert to hydro
Old Nov 21, 2002 | 02:55 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: Simple Engine Question!? (flexmyREX)
i think if you use b16a1 wiring you can keep it obd0...makes your wiring easier. hmotorsonline did this for my friend -
JDM B16A2 with A1 fuel rail and injectors (and resistor box?)
YS1 LSD tranny (cable)
PR3 ECU (OBD0)
i think that all you need is the 1st generations fuel system to keep it OBD0...im hope somebody will tell me if i am wrong
thats all that comes to mind right now.
Old Nov 21, 2002 | 03:16 PM
SIRBUSH's Avatar
Default Re: Simple Engine Question!? (fastcrxsi90)
Thanks. Does anyone know the differnces between a b16a and b16a2. Mine is not nearly as loud in vtec as my friends 99 SI, it really bothers me I have a b16a by the way also what are some general tuning guidelines to follow to tune the car
[Modified by SIRBUSH, 9:34 PM 11/22/2002]
Old Nov 22, 2002 | 07:07 AM
sorry...you'll need to keep your 1st gen distributor. i knew i was forgetting something!
the internals are a little different between the 2 motors. plus your motor is probably at least 8-9 years older than your friends. different intakes and exhausts might make it sound louder!?!?!
kp
Transmission & Drivetrain
10
Apr 28, 2009 09:09 AM
Jspek9666
Aug 10, 2007 02:14 AM
TeamCivic
Apr 23, 2003 01:56 PM
NiiS
Jun 7, 2002 03:53 PM
CivicTypeR
Jul 14, 2001 02:45 PM
