exhaust piping question...
Old Nov 21, 2002 | 01:07 PM
LudeyKrus's Avatar
Default exhaust piping question...
I have a new muffler, and I wanted to make a whole catback. A shop around here will weld it onto a new 2.25" catback for 70 bux. The only problem is i am pretty sure they'll be using crush bends. So my question is: which is more restrictive, the stock piping (1.75" or 2", not sure), or 2.25 w/ crush bends?
Old Nov 21, 2002 | 01:19 PM
PrecisionH23a's Avatar
Default Re: exhaust piping question... (LudeyKrus)
the smaller the piping, the more restriction it adds. but, with crush bends it will add turbulence to the exhaust flow. your best bet is order mandrel bent pipes from jeg's then have the shop cut it up and fabricate it from there if you are that concerned.
Old Nov 21, 2002 | 02:20 PM
killaludeSi's Avatar
Default Re: exhaust piping question... (GudeH23a)
wow its a common misconception, that smaller exaust pipe is bad. this is not always true, it really depends on how much power your engine is producing, if you only have a few mods, smaller is actually better. If you have turbo you will need bigger exaust piping....check this link out..... http://www.hondalife.com/articles/backpressure.htm
Old Nov 21, 2002 | 03:18 PM
LudeyKrus's Avatar
Default Re: exhaust piping question... (killaludeSi)
well, soon i will be running nitrous *hopefully*, so I want something a little bigger; but i can't afford mandrel bent piping right now. So it's stock, or crush bends...
Riceball
Welding / Fabrication
Jul 21, 2006 08:29 AM
blackv6
May 21, 2006 08:37 PM
Fugeeu
Aug 21, 2004 01:35 AM
drjondurst
Mar 14, 2003 10:32 AM
accordfreak
Mar 12, 2003 09:42 PM
