secondary o2 sensor
Old Nov 21, 2002 | 07:36 AM
RSvtec's Avatar
Default secondary o2 sensor
how do i get rid of this code? i made a straight pipe and this light is been on for awhile now. i know its the catalytic converter but is there anyway to trick the ecu? and i saw this o2 simulator while i was searching the web....does this work?....thanx in advance
Old Nov 21, 2002 | 08:49 AM
Kataku2K3's Avatar
Default Re: secondary o2 sensor (RSvtec)
You can just have an oxygen sensor port welded in to your straight pipe..... When I have done this in the past say to run open header I normally just plug in the O2 and zip tie it up somewhere..... It has no input on how the car runs, that's the job of the primary...
Old Nov 21, 2002 | 12:23 PM
m0t0rhead's Avatar
Default Re: secondary o2 sensor (JDMspecEG6)
OBD2 vehicles retard ignition timing and add fuel when it senses dirty emissions.
Old Nov 21, 2002 | 12:45 PM
nolimits's Avatar
The secondary O2 will throw a cel, but will not put the car into limp mode. It's purpose is an emmissions check, not engine control. Get a simulator, follow the instructions, and your cel will be gone. Until then, the light in your dash is the only effect, engine will operate as normal.
Old Nov 21, 2002 | 12:47 PM
nolimits's Avatar
Also...don't waste your time welding the sensor into your straight pipe, it will still throw a code 67....
Old Nov 21, 2002 | 10:44 PM
RSvtec's Avatar
Default Re: secondary o2 sensor (00turbosi)
thanx for the info guys but where can i get a o2 simulator?
Old Dec 8, 2002 | 12:28 PM
hub_01_69's Avatar
I also need a simulator. Does anyone know where they can be purchased at?
Thanks
Hub
Old Dec 8, 2002 | 06:48 PM
NVMYSi's Avatar
Default Re: secondary o2 sensor (hub_01_69)
me to, where do I get one at?
8083tcman
Dec 31, 2008 12:55 AM
Hyper2k
Feb 14, 2007 10:13 AM
srb7f
Oct 14, 2005 07:01 PM
teg2000gs
Oct 26, 2004 11:02 AM
b16wannaride
Sep 16, 2002 12:02 PM
