Spun rod bearing. Can it be fixed??
Old Nov 20, 2002 | 08:24 PM
AndyD's Avatar
Default Spun rod bearing. Can it be fixed??
Hey guys, I am buying an H23 motor that has a spun rod bearing ( I am getting it for dirt cheap) and I was wondering if this can be fixed at minimal cost? How much to fix?? Can I do it myself??
Thanks
Old Nov 20, 2002 | 09:13 PM
satan_srv's Avatar
Default Re: Spun rod bearing. Can it be fixed?? (AndyD)
You have to replace the rod and likely the piston....
Old Nov 21, 2002 | 04:57 AM
AndyD's Avatar
Default Re: Spun rod bearing. Can it be fixed?? (satan_srv)
Oh, ok. Do you think anything could be wrong with the block??
The guy said that it still runs.
Old Nov 21, 2002 | 05:02 AM
aklucsarits's Avatar
New User
The more he continues to run the motor with a spun bearing, the more likely it is that the crank or block is damaged too...
Andrew
Old Nov 21, 2002 | 05:11 AM
satan_srv's Avatar
Default Re: Spun rod bearing. Can it be fixed?? (aklucsarits)
The fact that it runs is good in a sense...the rod hasn't fused itself to the crank...at this point the crank should be okay....
Ask him about oil consumption...that will give you an idea of the condition of the pistons/rings...
Old Nov 21, 2002 | 05:14 AM
AndyD's Avatar
Cool. He only ran the car for a few minutes. He got a JDM H22 swap. I am getting the whole H23 swap for pretty cheap so I just want to take the engine apart. I would like to fix it if I can...but if I can't ...no big deal.
Thanks for ALL the help guys. I REALLY appreciate it.
Old Nov 21, 2002 | 05:17 AM
satan_srv's Avatar
Do a compression and leakdown test before you buy
Old Nov 22, 2002 | 03:26 PM
thatchmaster's Avatar
New User
If you're getting something with a spun bearing.... well--you could try to just get an oversized OEM bearing for it; but I'd really recommend taking it to a shop, have it line bored, and have the crank journals checked out. It'd be worth the time/money. Those problems can get nasty... especially when you're dealing with oil pressure problems (bearing clearances relate directly to oil pressure).
-Erik
anyya8
Jun 25, 2011 07:50 AM
shandonwall
Mar 27, 2009 10:54 AM
pentaq
Jan 10, 2009 03:17 AM
99blackvti
Oct 26, 2005 05:41 AM
hybridpatient95
Apr 26, 2005 01:12 PM
