vehicle speed sensor is not working properly....
Old Nov 20, 2002 | 08:06 PM
mattt's Avatar
Default vehicle speed sensor is not working properly....
My vehicle speed sensor is not working properly 97 sedan with b16a2 swap. The speed fluctuates (spelling?) alot, sometimes it does not function at all. I get a cel too.
Does a faulty vss affect anything else than my speedometer? Should I replace it asap?
What should I check first?
moved to tech...
[Modified by mattt, 2:09 AM 11/22/2002]
Old Nov 21, 2002 | 04:58 PM
mattt's Avatar
Default Re: vehicle speed sensor is not working properly.... (mattt)
ttt
Old Nov 21, 2002 | 05:00 PM
tominos's Avatar
my friend with 90 integra with b16a1 swap does the exact same thing. sometimes cel comes on and sometimes speedometer works, when he first got it, it use to fluctuate sometimes working and sometimes not. but after about 2 weeks, just started working again. hmm, weird.
Old Nov 25, 2002 | 06:11 PM
92gsrhatch's Avatar
check the connection, if it has oil in it then the bottom half is bad. if water gets in it then it will flutter like that. if the sensor it self is bad just take it apart,the two 10mm screws, the top half will come off and you can use any one off a 92+ 5-speed, it will work!
Old Nov 25, 2002 | 06:24 PM
TRE_'s Avatar
Default Re: vehicle speed sensor is not working properly.... (92gsrhatch)
On automatic cars the VSS effects when the tranny shifts, but since your car is probally a manual it wont have any effect on shifting points. It also sends your vehicle speed to your speedometer, and has a little to do w/ your air/fuel maps.
Old Nov 25, 2002 | 06:46 PM
dinosa21's Avatar
Default Re: vehicle speed sensor is not working properly.... (HybridJDMHonda)
friends car did the same thing check the conection.
Freckles
Aug 20, 2012 10:30 PM
Chrizcrozz
Aug 31, 2011 09:33 PM
blaze.1
Sep 10, 2009 06:24 AM
aziaticvang
Jan 13, 2008 06:35 PM
eg u y
Sep 27, 2004 10:28 PM
