sir cluster question
Old Nov 20, 2002 | 06:36 PM
josups's Avatar
Default sir cluster question
if i buy the sir cluster (which i most likely am) where do i hook the tach wiring up to, is there an existing plug? any help would be greatly appreciated.
Old Nov 20, 2002 | 06:42 PM
robsir00's Avatar
Default Re: sir cluster question (josups)
If memory serves me right the wires that you disconnect are pluged in the same way into the cluster and the tack will function i think it was the yellow connection.only for 96-00 civics
Old Nov 20, 2002 | 06:47 PM
slooowDX's Avatar
i'm guessing you have a 92-95 cuz of your avatar, well no adding wires/finding ones to hook up, its plug and play hommie
[Modified by slooowDX, 7:47 PM 11/20/2002]
Old Nov 20, 2002 | 06:50 PM
josups's Avatar
Default Re: sir cluster question (slooowDX)
thanks for the help, do you guy's know if the install is hard at all? yeah, i got a 92 dx. thanks again, now who said h-t members are ********?
Old Nov 20, 2002 | 06:55 PM
93SSPHatch's Avatar
SUPER EASY. I think the SRS (green plug) may not have a home in the SiR cluster, don't quote me on that. I decided to use a 95 Si cluster, and the swap was easy as hell.
Good luck!
43!
Jul 24, 2014 12:01 AM
YEAH!
Sep 23, 2011 02:42 PM
CivicHB93JDM
Apr 22, 2005 08:50 AM
letsroll
Aug 23, 2003 07:53 PM
