Turbo Parts List (What am i missing...?)
Old Nov 20, 2002 | 04:57 PM
JV's Avatar
JV
Who?
Default Turbo Parts List (What am i missing...?)
I'm putting together a kit and need some guidance as to what i still need to get.
Things i have:
T3/T04e 60 trim w/ .63 ar
Inlinepro T3 mani
Drag IC *core* 22.5" x 12.5" x 2.25"
Tial 35mm WG w/ .45 spring
Greddy Type S BOV
Things i know i need:
Oil lines
IC Piping
DP flange
Down pipe
Hondata s100 or s200 (Can't decide)
RC 440 Injectors
255lph Intank fuel pump (Is this necessary with larger injectors + hondata?)
Please feel free to add anything i may be missing from the list...
Thanks, Jay
Old Nov 20, 2002 | 05:06 PM
APEX i GSR's Avatar
Default Re: Turbo Parts List (JV)
resistor box
Old Nov 20, 2002 | 05:12 PM
CRXGSR's Avatar
Default Re: Turbo Parts List (APEX i GSR)
boost controller, turbo timer, boost gauge
Old Nov 20, 2002 | 05:13 PM
Flamenco-T's Avatar
you may need fuel preessure regulator, or stock may do it for now...
you also need resistor box and OBD1 imjector clips to run the injectors peak and hold
for DP, I suggest get a flange and get a U bend and cut it to fit, it's basically, flange, then ~130 deg ish bend, then goes down, then it's a 90 deg to clear the oil pan to the exhaust..you also need flex pipe to match the DP as well...
I have regular 2.5" DP, I am converting it to 3", it has the last 90 deg and flex piping to go to the exhaust, with it all you need is the flange and the U bend to make the DP
IC piping is easy, ,run 90 deg bends from the compressor outlet to the IC, then run a U bend on the other side of the IC ( get at elast 6" radius U bend to clear the chassis) then it's just a couple more 90 deg bend, then the 45 - 60 deg bend to the TB
I can make you a diagram if you want...may be different for civic, but you'll get the idea
If you're planning on boosting past 11 psi, get a 3 bar GM map sensor and the harness.
I can get you oil lines, return and feed cheap if you want, I still have a few fittings left over..
HTH
stan
Old Nov 20, 2002 | 05:23 PM
technine's Avatar
Default Re: Turbo Parts List (Flamenco-T)
Don't you mean OBD0 injector clips?
Old Nov 20, 2002 | 05:25 PM
sutrusu's Avatar
Default Re: Turbo Parts List (technine)
he's not running peak and hold injectors, he says he's gona get RC 440, which are saturated. you dont need a resistor box if you get the right ones (saturated)
Old Nov 20, 2002 | 05:29 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Turbo Parts List (sutrusu)
Yep, make sure you ask though. I remember RC having all their injectors over 440 as peak and hold. Just check to make sure.
You can actually save yourself the $40 on the injector clips if you mod the clip yourself. Just take a look at the new RC plug and the stock wiring harness plug. Just trim a little off the middle section and you're good to go.
Old Nov 20, 2002 | 05:50 PM
JV's Avatar
JV
Who?
As of right now i have a B&M FPR and i'm planning on getting the 440 saturated injectors from RC so i can avoid having to use a resistor box...
This brings up another question.
Is it Ok for me to run the compressor on the driverside or will that put too much stress on the manifold?
I have already "mocked" it up this way and it seems like it would place alot of the weight towards the "outside" of the manifold. Could this lead to cracking?
I have a good idea on how to run the piping, but a diagram might be good for "archive" purposes...
That would be great... IM me please...
Thanks, Jay
Old Nov 20, 2002 | 06:10 PM
johnisenglish's Avatar
Default Re: Turbo Parts List (CRXGSR)
Yeah, definetly want some good gauges, Boost, Oil Pressure, EGT, etc
Old Nov 20, 2002 | 06:19 PM
BoM's Avatar
BoM
Default Re: Turbo Parts List (johnisenglish)
a clutch now? or when you burn your stock one out.
Old Nov 20, 2002 | 06:22 PM
Flamenco-T's Avatar
Default Re: Turbo Parts List (BoM)
gotta feel the wratch of stock clutch with boost first before repalcing it hehehehehe
I got stock clutch for 10K miles...it was fun hehehehehe
Old Nov 20, 2002 | 06:58 PM
JV's Avatar
JV
Who?
New clutch is a definite...
Old Nov 20, 2002 | 07:08 PM
vtec.dc2's Avatar
Default Re: Turbo Parts List (shamoo)
440cc from RC are available in saturated, the next size might not be byt can be custom ordered. and resistor box isn't necessary for saturated type.
Old Nov 21, 2002 | 04:21 AM
JV's Avatar
JV
Who?
Bump
Just want to be sure i got everything covered...
harwood39
Dec 28, 2004 06:16 PM
98Spec EK
Jun 18, 2004 04:29 PM
Tru Dynamix
Mar 2, 2003 09:41 PM
95c1v1cs1
Feb 19, 2003 04:34 PM
vtec.dc2
Dec 13, 2002 02:48 PM
