Can HID bulbs blow?
I don't see why not, but for some reason I just figured they didn't... My dad has a 99 3.2TL, and last week one of his headlights stopped working. For a while it would come on for about a second and then fail to warm up.. but now it's dead all together. Anyone have any idea whats wrong? Any idea how much repair costs will be?
Pull the bulb out and take a look at it. If it is physically broken there is your problem. Another suspect would be the ballast, check all the connections. Turn on the lights and listen for a humming from the ballast. If you don't hear anything that is probably the problem. Both bulbs and ballasts are somewhat expensive.
after u check that everything looks ok.. do the following
step 1:
check your fuse
step 2:
check connection to bulb
step 3: swtich bulbs from left to right and see if its the bulb or ballast?
if its the bulbs, let me know.. i can get them cheap hell i have a ton running all over so let me know and i'll see what i can do for ya
step 1:
check your fuse
step 2:
inspireAZN
Lighting
17
Jan 14, 2008 09:54 AM
