Accord Type-R valves
Anyone know where I can get these? They are lighter and better design than stock H22a valves...
Get one of the mags written in England and find the phone of a Honda dealer located over there.
i want some ATR valves. how much would they run for all 16?
Now it's a matter of figuring out if the type-s valve angle is different....
Now that I'm back on the boards again... figure I'll be of some use.
I grabbed this from the 'ol asia vtec.net site.
"The valve seat was re-adjusted from 60 to 45 degrees. Finally, the cylinder head and intake port was treated to a manual port-&-polish job by Honda technicians"
I'm sure if you ended up getting a set of S valves, you'd take care of the seats anyway right? If you're going to get valves, it may not be a bad idea just to go with Ferrea's.
-Erik
-Erik
Guest
Posts: n/a
imo id get the skunk high compression valves, they are lighter than stock and the bottom is slightly domed for more compression... i think they add 0.4 to the compression. combine that with a thin headgasket and you have about one point higher compression
only problem is.. if something goes wrong, aftermarket valves shatter and will really f*-up your engine.. honda OEM valves bend, still not good for the engine, but they atleast remain in one peice instead of falling into the combustion chamber
tommyleeruiz
Jul 29, 2008 06:57 PM
