What cams are best??
Old Nov 19, 2002 | 09:30 PM
bokguay's Avatar
Default What cams are best??
OK...im shopping for cams right now and im debating whether to go with Toda spec B's or to go with SK2 stage 2 cams...give me any info u guys can...what do think is best...thanks
[Modified by bokguay, 6:35 AM 11/20/2002]
Old Nov 19, 2002 | 09:45 PM
LB CRX's Avatar
Default Re: What cams are best?? (bokguay)
IMO i would go with stage 2 skunks as long as you get the valve train to go with it.
Old Nov 19, 2002 | 10:06 PM
POLLO's Avatar
Default Re: What cams are best?? (LB CRX)
With either set up I recommend each propietary valve train set up. Make sure if running Toda cams to also use their camgears as well ( I will give you more info on that if interested.)
Honestly if workign on a street set up I would go with skunk 2 stage II those idle quite nice also.......
the same you are spending for Toda cams you can also be spending on Jun type 3's. But for the price, you might as well get the Skunks(stage II) since they are based of Jun 3's specs with a very little difference on some areas( but you didn't hear that from me )
Old Nov 19, 2002 | 11:54 PM
poo flinger
Guest
Posts: n/a
Default Re: What cams are best?? (POLLO)
Like everyone said, Skunk2. I have a pair myself and love them.
If you are gonna drop that kind of money on cams, I would hope you take them to the dyno.
Oh, btw, check your other post.
Old Nov 20, 2002 | 12:41 AM
bokguay's Avatar
Default Re: What cams are best?? (I cant believe this ****)
thanks man
Old Nov 20, 2002 | 02:49 AM
1 Special CTR's Avatar
go to http://www.importreview.com they have all kinds ofd reviews on cams
Old Nov 20, 2002 | 03:12 AM
LHC's Avatar
LHC
have you searched? 'cose not long ago we had a huge thread go through skunk2's vs TODAs...
Old Nov 20, 2002 | 08:07 AM
advanracing62's Avatar
Default Re: What cams are best?? (spoonedcivicG4)
JUN III, hands down!
Old Nov 20, 2002 | 09:22 AM
owen_the_soyboy's Avatar
TODA spec D is the best.
and yes they are available now.
but they may be too much for you if you need to ask which is best....
Old Nov 20, 2002 | 10:01 AM
Default Re: What cams are best?? (owen_the_soyboy)
LMFAO
thumper77fox
Apr 6, 2006 09:31 AM
^AnDre^
21
Dec 13, 2004 09:36 AM
SaTownTegGsr
Sep 9, 2004 10:25 AM
HighCompression
Nov 4, 2002 10:49 PM
SpoonFed
Dec 5, 2001 02:39 PM
