stock resistor box on 90 prelude si
Old Nov 19, 2002 | 08:02 PM
BoostedB20A's Avatar
Default stock resistor box on 90 prelude si
Will the resistor box, if thats what it is I am looking at, work for road race 550 injectors? It looks to be the same as the crx ones. Am I wrong? If I am please tell me what I need to do to run these 550's in my 90 prelude. This is only my second day as a member here, so if someone can give me a walk through of how to post a pic for you to see what I am talking about I gladly will. Thank you.
Here is my shot at posting the pic:
[Modified by BoostedB20A, 5:10 AM 11/20/2002]
[Modified by BoostedB20A, 5:12 AM 11/20/2002]
Old Nov 19, 2002 | 08:14 PM
Default Re: stock resistor box on 90 prelude si (BoostedB20A)
Ok, I cant post a pic. But if you go to http://www.picturetrail.com then where it says "visit album" type in "craiglude" and you will see all the pics of my car. Please check out the pic of my resistor box and let me know if that is the one I need. Thanks alot guys.
Old Nov 20, 2002 | 07:14 PM
No one has any idea?
Old Nov 22, 2002 | 07:31 PM
anyone at all?
Old Nov 22, 2002 | 08:11 PM
boostaholic's Avatar
That's the resistor box. If you follow the wires leading out to it they should go to the injector part of the main wiring harness. Should be 4 red and 1 black wire. If the 550cc injectors you're using are low impendence then yes you can use that. HTH
milllllkman
Jul 2, 2006 08:49 PM
hontegra
Apr 26, 2004 10:23 AM
ForceFed Coupe
Jan 5, 2004 11:21 AM
redboost10
Oct 23, 2003 03:35 PM
