Rear Sway Bar torque(lbs) setting.
Old Nov 19, 2002 | 07:47 PM
DarthLuder's Avatar
New User
Default Rear Sway Bar torque(lbs) setting.
Well ever since it got cold here in Chicago. The rear sway been making some creeking sounds. I never lubed the bushing before installing the Mugen rear sway bar. I also didnt use a torque wrench.(loose bolts???) So does anyone know the torque settings for the rear sway bar. thanks, Dan
Old Nov 19, 2002 | 07:58 PM
Understeer's Avatar
Default Re: Rear Sway Bar torque(lbs) setting. (ITR GURU)
16 lbs/ft
Old Nov 19, 2002 | 08:21 PM
DarthLuder's Avatar
New User
Default Re: Rear Sway Bar torque(lbs) setting. (Understeer)
16 lbs/ft
thanks, do you happen to know the torque setting for the two bolts on the side?
Old Nov 19, 2002 | 08:31 PM
Junior_r's Avatar
22 lbs-ft
Old Nov 19, 2002 | 08:35 PM
DarthLuder's Avatar
New User
Default Re: Rear Sway Bar torque(lbs) setting. (Junior R)
22 lbs-ft
22lbs for the endlink bolts and 16lbs for the 4 bolts. Thanks,
Edit: MY 400 post
[Modified by ITR GURU, 5:36 AM 11/20/2002]
Old Nov 20, 2002 | 12:43 PM
Chris N's Avatar
Mine is also squeaky - well greased AND torqued. No idea why....
Old Nov 20, 2002 | 06:51 PM
DarthLuder's Avatar
New User
Default Re: Rear Sway Bar torque(lbs) setting. (1107)
It might be the cold weather. The car is a 01 also.
Old Nov 20, 2002 | 06:52 PM
Chris N's Avatar
i've come to love all the squeaks and wierd sounds that come from the R in the winter. There are sooo many more wierd sounds when it gets cold out.
Blacknight117
Suspension & Brakes
10
Sep 3, 2012 08:37 AM
Beau Gotti
Suspension & Brakes
Nov 5, 2006 10:18 PM
Vera
Dec 31, 2005 08:29 PM
