1990- Honda accord- Fast Idle Problem
Old May 3, 2026 | 04:31 PM
RocRaider's Avatar
Default 1990- Honda accord- Fast Idle Problem
Hello,
I am looking for assistance and troubleshooting a 1990 Honda Accord that has a high idle problem. When I fire up the car it will stay at around 3,000 RPM and not go down.
I replaced the idle solenoid and Idle air control valve. And by replaced I mean I got two at Pick-n-Pull to test and troubleshoot. From what I can tell these are not the source of the problems. I've also ensured that my coolant is up to level.
In addition to troubleshooting with spare parts from Pick-n-Pull, I've also removed these and deep clean them and blew them out with compressed air, flushed them out with carb cleaner and clean them with a wire brush.
Where would you troubleshoot next? What am I missing? What else controls the idle?
Here's a video that helps demonstrate what I'm talking about.
Link to Video
Any help is appreciated!
Old May 4, 2026 | 09:38 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1990- Honda accord- Fast Idle Problem
Did you inspect the FITV?
Fast Idle Thermo Valve
https://honda-tech.com/forums/honda-...tv-tb-1844067/
Over time it can loosen up and keep the idle high.
However if it is 3K that may be a vacuum leak, check PCV and brake booster lines as well as all other vacuum lines attached to the 'boost valve' that is attached to the end of the plenum.
Spray TB cleaner around intake maifold and TB gaskets as well as injectors.
If this has just started happening, recheck any recent work done. Even if it was not engine related something that 8s engine related may have been disturbed.
Vicren
Feb 19, 2021 09:17 AM
claire
Dec 3, 2012 12:24 PM
KristjanL
Dec 29, 2011 05:07 PM
treym187
Feb 17, 2011 11:10 AM
majek
Jul 16, 2005 08:22 PM
