Auto 16y8 - S20 manual swap
I believe I know everything I need for the swap, but would someone tell me a list of everything I need? I just want to be sure I have everything before I take the daily out of commission. I currently have the s20 - shift linkages - starter - axels - mount - clutch and flywheel.
2 wire IACV if you swap ECUs. You can reuse your intake manifold if you drill and tap holes.
You can get by with the automatic ECU for the time being with the 3 wire original IACV
Don't forget all three pedal assemblies, the clutch slave cylinder and a C2 conversion harness. I would also get a complete manual Y8 intake manifold and Y8 manual ECU and move the black/blue wire at the ECU plug end to convert from a 3-wire IACV to a 2-wire one. You will also have to change the connector at the IACV end of the engine harness to plug into the manual IACV.
tbud454
Apr 13, 2020 09:53 PM
CivicHP
19
Jun 3, 2005 07:35 AM
