OBD0 DIZZY WITH P28 ECU
Old Apr 26, 2026 | 12:24 AM
blackegnenadm's Avatar
Default OBD0 DIZZY WITH P28 ECU
Hey,
I need to know if it's possible to run a P28 Ecu to a OBD0 distributor. I swapped my d15 block from d15b2 to a d16 with p29 pistons, and now the car is not pulling past 5500rpm. It has noticeably more power, but suffoces up top where it matters. I tried swapping an obd1 dizzy but it doesnt mount on my head, the shape is way different. Is there a way for me to install my p28 ecu while keeping the current obd0 distributor?
Old Apr 26, 2026 | 08:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: OBD0 DIZZY WITH P28 ECU
Unfortunately not. The OBD-0 distributor has a 16 tooth wheel whereas the OBD-1 and 2 distributors have 24 tooth wheels for the CKP sensor. The ECU cannot manage proper ignition timing with this incongruity.
Old Apr 27, 2026 | 05:11 AM
Thank you very much. I will get a new head that's OBD1 from factory. Do you have any recommendations for a D16 high compression build, that's not Z6, since i can't find a single one in my country..
Old Apr 27, 2026 | 08:03 AM
speedooo's Avatar
What head?
Old Apr 27, 2026 | 11:16 PM
Originally Posted by speedooo
What head?
From D15B2..but I just got a B7 head that has the mounting points exactly for OBD1 so that should fix my issue.
Old Apr 27, 2026 | 11:59 PM
Chrisfrom1986's Avatar
A z6 distributor will only fit a z6 head, you must use the d15b7 obd1 or d16y7/y8 obd2 distributor.
Old Apr 28, 2026 | 07:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Moving from a B2 head to a B7 head solves the distributor mounting issue as long as you use a B7 OBD-1 style distributor with it.
Old Apr 29, 2026 | 01:21 AM
Thank you very much. That's exactly what I'm gonna do and I'll update once done. I got the head coming in today and I'm picking the dizzy up tommorow.
itrdelsol
Aug 16, 2006 06:09 AM
6kZ
Jul 23, 2006 08:31 AM
89silverb16crx
15
Apr 14, 2004 10:02 PM
Dragger817
Oct 29, 2003 06:52 PM
