Low idle at cold start b18c
Old Apr 11, 2026 | 12:02 PM
krehzz's Avatar
Default Low idle at cold start b18c
So I have a jdm itr swap in my a 1999 hatch. Recently had it tuned (v300) by a reputable tuner.
only thing actually done to the motor is a skunk2 intake and TB. At cold start the rpm will sit at 600 and will sometimes almost die. When warm it will sit around 1000-1100. Tried to adjust cold idle in smanager but makes absolutely zero difference. Any sort of “idle” adjustment we make does nothing. It has a brand new iacv and coolant is full and bled. From what I can find there are also no vacuum leaks. I’m at a bit of a loss here as to what it could be. Any help will be greatly appreciated.
also everything seems to be reading perfect in the software which is also why I can’t understand what will cause this.
Tortugax626
Nov 17, 2019 11:10 AM
Dekorum
18
Mar 3, 2014 12:49 PM
Dekorum
Feb 28, 2014 01:07 PM
95Sedan
Oct 11, 2013 03:29 PM
