No luck with searches - shock questions
Old Nov 19, 2002 | 06:11 PM
Projected's Avatar
Default No luck with searches - shock questions
I'm sure this has been asked a million times but I can't find anything worthwhile in my searches.
I just bought stock ITR springs for my GSR, and need to purchase new shocks. I'm looking at Koni Yellows, KYB, Tokico, Bilsteins, ect. What have you ITR guys had the best luck with on the stock ITR springs? Thanks for any advice.
I'll being driving mostly Auto X's and some HPDE's are planned for next year. My car is also a daily driver. Thanks
[Modified by Projected, 10:20 PM 11/19/2002]
Old Nov 19, 2002 | 06:13 PM
Fuuma0083's Avatar
Default Re: No luck with searches - shock questions (Projected)
Koni
If Tein ever had the tech./rebuild support i would go with Tein
Old Nov 19, 2002 | 06:29 PM
Dave-ROR's Avatar
For ITR springs really any of those work. I'm a bilstein fan myself since I don't have to bother trying to adjust the dampener to the spring rates.
Old Nov 19, 2002 | 06:44 PM
Asahi's Avatar
Default Re: No luck with searches - shock questions (Fuuma0083)
Don't the Koni Yellows not have rebound/compression adjustment from the top in the rear?
Also TEIN DOES have support in the US. It is in Cali but Koni isn't exactly down the street from you.
I think Dave is right, Bilsteins are good for ITR springs.
Old Nov 19, 2002 | 06:54 PM
Dave-ROR's Avatar
Default Re: No luck with searches - shock questions (Asahi)
Bilstein's are good for more than that Mr "I lost to a GS-R with bilsteins" hahaha sorry trey, you know I'll pimp Bilstein against your Tein's anyday
Old Nov 19, 2002 | 07:55 PM
kkim's Avatar
nm
[Modified by kkim, 5:56 PM 11/19/2002]
Old Nov 20, 2002 | 06:55 AM
Projected's Avatar
Default Re: No luck with searches - shock questions (Dave-ROR)
Thanks for your advice guys
Old Nov 20, 2002 | 07:15 AM
emr88's Avatar
If you get the the Neuspeed Koni's, you can lower your car another .25" or .5" with the adjustable perches.
Old Nov 20, 2002 | 09:34 AM
typer_801's Avatar
Default Re: No luck with searches - shock questions (George Knighton)
To get the perch right, you can send them to ProParts, TrueChoice, or Koni NA and have a new ring cut in the shock at the correct height. Not sure on the cost, but I was quoted this when I was investigating get mine revalved for autocross and making the rear perch height legal.
Also, have you considered OEM ITR shocks? Their better than most aftermarkets and can probably be found used cheaper as well. Just my $.02
The rear Koni Yellows being sold by most resellers in the US have a rear spring perch that is too low. (<-Somebody put that in the FAQ!) Koni Yellows will therefore alter your car's basic handling attitude.
Old Nov 20, 2002 | 09:39 AM
emr88's Avatar
Default Re: No luck with searches - shock questions (typer_801)
He's putting these on his GSR, or at least he's got a GSR according to his message and sig, so he shouldn't have any problems with low spring perches.
Old Nov 20, 2002 | 12:55 PM
Reid's Avatar
Global Moderator
The only thing for which I'm sure the Koni Yellow rear spring perch would be correct is a CRX.
This uses the same rear shocks (as long as it's not a 88 CRX) as the GSR.
Old Nov 20, 2002 | 12:57 PM
Dave-ROR's Avatar
typer_801: yes, you can get them modified/fixed.. but why should you have to? That's right, you shouldn't have to.
George: GSR konis are completely different.
IMO, get bilsteins, I love them on my GS-R but I've already said that (and yes, they rock on ITRs too, in fact I need to install a set soon )
Old Nov 20, 2002 | 12:58 PM
Dave-ROR's Avatar
Default Re: No luck with searches - shock questions (Reid)
Koni uses the 88 CRX rear shocks for ITRs in the US. They wont fit a GS-R, that's for sure not that fam with CRXes to know if they changed the mounts, so I'll take your word on it.
Black R
May 19, 2012 09:13 AM
Murk 'EM
Feb 24, 2011 02:32 PM
danny98r
Sep 2, 2009 05:49 PM
Ill Mitch
Nov 2, 2006 11:56 PM
speedevo
Aug 31, 2002 05:13 AM
