D16Z6 help
Old Apr 5, 2026 | 07:34 AM
willep74's Avatar
Default D16Z6 help
Happy Easter to everyone!
I am stumped and hope someone might be able to shed some light on this. My son ran his D16Z6 turbo a little too hard and blew a head gasket. Took it off had the head machined and now the car won't start. Timing is good, spark is good, I get proper full pressure, getting 12 volts at the dizzy like I should and it refuses to start. It will sputter a few times if it sits for a while. It ran fine, other than the water consumption, after head gasket blew. Like I said I get 12v at the black/yellow wire at the dizzy harness when key is on, 0v when off.
I tried to get pics showing timing marks best I could. Any help is much appreciated!
Old Apr 20, 2026 | 03:37 PM
willep74's Avatar
Default Re: D16Z6 help
So I got a little further and I can get it to run, but dies as soon as iput it in gear. Runs great at 4k rpm. Not sure what I am missing, it's like I end up half a tooth off in timing.
thanks for all the replies.
Old Apr 22, 2026 | 05:43 PM
NVturbo's Avatar
O.G. triple O.G.
timing is definitely off. Set the crank pulley to TDC (back single white mark) and then the cam sprocket. Rotate it counter-clockwise one full revolution and see if it sets back to TDC
Gerardo Gomez
Nov 3, 2016 05:27 PM
HondaJDMLife
Nov 4, 2014 07:17 AM
97elitehonda
Apr 29, 2007 08:22 PM
EF9ZC
Mar 4, 2006 10:40 AM
