Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic 2003 no injector pulse on injector 2
Old Apr 1, 2026 | 08:47 AM
alextech's Avatar
5 Year Member
Default Honda Civic 2003 no injector pulse on injector 2
I have a Honda Civic 2003 and injector 2 is not pulsing, cannot figure out why. I had recently went to get my head resurfaced and new valve stem seals replaced. I have the fuel rail injectors out so i can check the injectors pulse and it fires in order 1-3-4 but there is no fuel coming from injector 2. I removed the injector 2 connector to check for ground on the yellow cable and it has ground. The fuel injector is good, i have changed injectors many times and i have a fuel injector tester to test the injector. I came to a conclusion that there is no pulse coming from the ECM. I have changed the ECM and programmed and its still the same issue. I dont know why this is happening. I'm thinking of replacing the wire to the ECM. I also checked for voltage on the red wire of injector 2 and has 12v. I need to figure out why this is happening. I'm going to check it more thoroughly tomorrow. Could somebody help me figure this out?
Old Apr 7, 2026 | 10:21 AM
alextech's Avatar
5 Year Member
Default Re: Honda Civic 2003 no injector pulse on injector 2
Hello update: after changing ECM. ECM now pulse but it seems to only work for 30 seconds and then it starts misfiring. It seems like the ECM, shut down the injector 2 on purpose. Here is video:
Fuel Injector Clinic
Sep 29, 2014 06:14 AM
boostedteg4dr
Nov 30, 2013 01:17 PM
rass1313
Nov 14, 2005 12:43 PM
oorob00
May 25, 2004 09:32 PM
lowboost civ
Apr 22, 2003 08:47 AM
