91 EF Hatch not starting but turns over.
Old Mar 4, 2026 | 04:16 PM
EFVSTH3W0RLD's Avatar
Default 91 EF Hatch not starting but turns over.
Sooo, I have replaced a lot of parts thinking it could be the problem but the car still doesn't start but It turns over. I have replaced the distributor, spark plug wires, spark plugs because it wasn't getting spark. Its getting fuel. The ECU turns on when i turn the key. I don't know what to do. Any help will be appreciated.
Old Mar 5, 2026 | 07:10 AM
dheurtley's Avatar
Loved
Default Re: 91 EF Hatch not starting but turns over.
What error codes are you getting? My car was turning over but would only start once a day. Turns out I had a hole in a coolant hose and the system was full of air bubbles so the coolant temp sensor couldn’t work properly.
In addition to the spark and fuel you also need the right amount of air for the car to start. Could be an issue with your IACV, air intake, throttle, etc. If you tell me how many red flashes you are getting on your ÉCU I can check my mechanic manual.
Old Mar 13, 2026 | 08:24 PM
Sorry for the late reply, I'm not getting any check engine codes. I have a new IACV, The engine was running great, I pulled it out to change the transmission because the one i had in it was welded and kept braking cv axles. So I put the 4 speed back in it. All I did was pull the engine and switch out the transmission. Now its having this problem. Thank you for the response
Old Mar 25, 2026 | 07:32 PM
I think it might be the ECU...
Old Apr 2, 2026 | 08:41 AM
Maxcapacity's Avatar
Did you forget to re-attach the ground to the thermostat housing?
Old Apr 6, 2026 | 05:29 PM
dheurtley's Avatar
Loved
Are you getting a check engine light? maybe try swapping to a good ECU to see if that helps.
Civic361
Jan 30, 2011 05:26 PM
2000siturboR
Nov 22, 2009 12:34 PM
Intellect
Jun 9, 2004 09:59 PM
