I was gone for a month and rats were able to make a nest in my cabin filter area. I deleted the ac/heater core cause it was shredded!! And disgusting. Well I was able to save some but I am having a hard time with these four grey wires. Not sure what goes to what?! Brake switch connector. Photo A Photo A Photo A Photo B Photo B Photo C Photo C Photo D Photo D. Cant find a diagram for these!!
Look closely at the green/red wires... there are silver "bands" on them and they are different patterns when bundled together, so you may be able to match up the wires simply by their band markings/patterns.
The 22-Gray connector is Connector C401. The light green/red wire is from the door switches to the ceiling lights. The light green/red wire is part of the door open circuit that also ties into the keyless receiver unit (in the stereo) and the keyless door lock control unit.
Possibly the power wires from under-hood Fuse No. 52 that feeds to (1) the brake switch, which then feeds the cruise control unit; and/or (2) power wires to horn relay contact or coil.
