Crank Pulley Help
Old Feb 18, 2026 | 05:02 PM
JRSC4me's Avatar
Default Crank Pulley Help
Ive been out of the game for years and now have resources and time to re connect with what i love. Am doing a boosted B16 build. Purchased a b16a3 block with crank and busted pulley. i am having the worst time in the world finding a crank pulley. Im getting mixed messages if i can run a B18B pulley. Ive checked online, junk yards, ebay, amazon, everything. I cannot find an OEM b16a crank pulley. Please someone tell me i can run the B18b...please.
Old Feb 18, 2026 | 07:19 PM
cdnsigop's Avatar
Default Re: Crank Pulley Help
Sort of in the same boat as you, building another Honda after many years. The Fluidampr pulley works on all B-series, 1990-2000 or something like that. You could possibly infer that the OEM pulleys are compatible across the B-Series.
You might not want to spend the money on one of these, but I put one on my 6.0 Powerstroke, and it is certainly a well built part...
https://fluidampr.com/honda/
Hope that helps!
Old Feb 18, 2026 | 08:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
OP, your username suggests an affinity for Jackson Racing Superchargers... will you be using one on your B16A3 ? If so, crank pulley selection is CRITICAL for your application. Using a B18B crank pulley will create a LOT more boost than the B16 crank pulley will. I believe my builder/tuner has some B16A crank pulleys on the shelf... if you would like his contact information, PM me.
Old Feb 19, 2026 | 06:40 AM
JRSC4me's Avatar
hey brother, the last time I used this site thats what I was running on my integra but that's long gone. As I said, im finally getting back in game with a turbo B16a build. I really want to avoid a $400 fluid damper setup that has to be press fit on the crank. I have a line on a good condition B18B crank pulley but I cant find info if it will work on a b16 setup. I know it will bolt right on, i just want to confirm it will dampen the vibrations like the one that originally came with the b16 block.
Old Feb 19, 2026 | 06:47 AM
JRSC4me's Avatar
Hope that helps!
thanks for suggestion. I am trying to avoid those for 2 reasons, price and they have to be press fit into the crank which means once its on there if I ever have to get in there for some reason the motor has to be yanked. Ive got a line on a B18B pulley, I just need to know if the dampening will hold up to b16 revs.
Old Feb 19, 2026 | 07:54 AM
Grade50's Avatar
10 Year Member
You sure you cant find one online? They've been out of production for a long time now. I believe its part 13810-P2T-003
Maybe something like, but cant be sure: Brand New Crankshaft Pulley / Harmonic Balancer For Honda # 13810-P2K-003 | eBay
Heck, I think you can get them on rockauto More Information for ATP 102280
Could be wrong, but is the part number I have written down in the event I ever needed to find one.
Old Feb 19, 2026 | 08:12 AM
spAdam's Avatar
Loved
Community Favorite
You definitely don’t need to pull the engine to press off a crank pulley, I don’t know where you got that info from. You do need a ~$100 toolset to do it.
Problem with the OEM pulleys is that they’re all pushing 30 or more years old and you have no idea the history of one or the condition of the elastomer layer until it fails and/or ruins something else. The $400 for an ATI or Fluidampr is an investment in peace of mind as much as it is for engine protection.
Old Feb 19, 2026 | 08:30 AM
JRSC4me's Avatar
here's problem.in listing is says good for D and B series motors. Thats 100% wrong not only is the size different but the balancer for d series is different for b because of the B revving higher
Old Feb 19, 2026 | 08:33 AM
JRSC4me's Avatar
I understand. At the core of this i just need someone to say "yes, that b18b pulley will work just fine on a B16 build" or " no, that pulley will not work". That way i know if my only choice is the ATI.
Old Feb 19, 2026 | 07:43 PM
Z31freak's Avatar
Found one in ebay and cheap supposedly it fits the b series engines.
https://www.ebay.com/itm/36054914627...tedSearch=true
And here's a screen shot for those weary of links
and like you i also just got back to the honda scene.
Old Feb 19, 2026 | 08:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The B18B crank pulley will work. The Fluidampr product does NOT have to be pressed on and off of the crankshaft snout... it is a "slide on" fit just like the OE pulleys are. The ATI dampener/crank pulley is a friction fit and has to be pressed on and off... which means you must use the pulley puller kit spAdam mentioned above.
Old Feb 20, 2026 | 05:20 AM
JRSC4me's Avatar
Thats not OEM. Thats a cheap "lightweight" with no internal dampening. Those things are what will blow up a high revving motor
Old Feb 20, 2026 | 05:23 AM
JRSC4me's Avatar
just out of curiosity, why wont it work. Also, thank you for that info about the other 2. I had an ATI saved in list but if the other one can be removed just like the OEM that's the way ill go.
Old Feb 20, 2026 | 07:03 AM
Grade50's Avatar
10 Year Member
Notice that Fluidampr has special directions for b-series engines, and it makes no mention of pressing it on.
If you get it, can you let us know how it works out? I still have the original OEM; gettin old.
Old Feb 20, 2026 | 05:11 PM
JRSC4me's Avatar
hey, sorry, your reply did not show itself
Old Feb 20, 2026 | 07:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
WHAT ?!? I said that the B18B crank pulley WILL work... you will likely have to replace some belts because they will be different sizes than what comes stock on a B16A... two accessory grooves are larger in diameter and one is smaller.
Your font color is white... on a WHITE background !!! No one can read it !!! Please change your font color back to the DEFAULT BLACK... like everyone else uses.
Old Feb 21, 2026 | 03:15 AM
theYBLEGAL's Avatar
Loved
For the ATI pulleys I've installed, I've had to lightly hone the inside of the pulley to get them to fit. Even heating sometimes is not enough.
ATI dampers also require a diff size alternator belt because the pulley size is under-driven. Not sure about fluidamper, likely same
The crank snout on all B series motors are the same. The only diff with pulleys are accessory driven ratios.
Font color...lol always fun. I always use this site in dark mode, dark background. If you don't modify the text color at all, the site will make it white on black background or black on a white background. You should not ever change the font color when replying. Automatic is bestest
Old Feb 21, 2026 | 04:09 AM
Grade50's Avatar
10 Year Member
Calm down. I did not change any font color. Ol HT has some issues apparently.
Old Feb 21, 2026 | 08:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Right... the site messed up for you and only you... but works perfectly for all of the rest of us. Makes sense.
Old Feb 27, 2026 | 10:13 PM
cdnsigop's Avatar
I'm going to give the Fluidampr a try for my B16. Amazon.ca of all places seems to have the best price. Can that really be the case!?
Old Feb 28, 2026 | 08:59 AM
spAdam's Avatar
Loved
Community Favorite
Totally possible. Just make sure it's a legit seller and go for it.
Old Feb 28, 2026 | 09:32 AM
Grade50's Avatar
10 Year Member
Are you honestly trying to pick a fight with me over font color you turd?
Old Feb 28, 2026 | 10:59 AM
cdnsigop's Avatar
No doubt! Of all things, Amazon is the seller and shipper. So they must be a distributor for them? They also had an unbeatable price on Exedy's Stage 1 (08800B), same deal, sold and shipped from Amazon...
Maybe no one can match their buying power? Just never dreamed of buying parts like that off Amazon!
Old Feb 28, 2026 | 02:00 PM
JRSC4me's Avatar
sorry, dont know why I read it as will not work
Old Feb 28, 2026 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
No fight... just calling it as I see it. Are you still butt-hurt a week later ?!?
