question for guys with dc jdm header
I had my DC JDM header installed a few months ago and I already had a DC sports cat back exhaust. Ever since I installed the header and carsound high flow cat my exhaust doesn't stay on the rubber mounts in the back. The hooks keep coming off. The exhaust is set too far back and needs to be pushed towards the front of the car but it can't be pushed up anymore. So my question is to those with the DC JDM header did you have to cut a piece of your exhaust piping and then weld it back together to make the exhaust fit right on your car with the new header? Thanks for your replies.
the exhaust it self sits way out...it sat out far on my si,ever since the jdm header install that thing sticks out even further.Btw i also have a carsound cat.
after i got this thing it sat far out so i had to cut it and U-bolt it
now it's fine
if you can find anywhere that you can cut~ go ahead
otherwise it will OWN your rear bumper
Did you try loosening all the nuts/bolts and pushing it as far forward as you can. While you have everything pushed up (hold it there) have someone go thru and re-tighten everything. I know that's worked on other cars before. Good luck.
now it's fine
now it's fine
hehe
well. find a place that you can cut~ not the actualy pipe but somewhere that connects header and cat.
cut them and u bolt it or weld it
good luck
good luck
i had the same problem on my gsr. After installing the header and cat, it pushed my whole exhaust back about 3/4 inch and it rattled and rubbed against heat shields.
now it's fine
sounds like a problem with either your exhaust bushings (mounts) or the size of the cat/testpipe. The DC sports exhaust should sit in the same location as stock...since I have both on my ITR and Civic and have no problems with them.
sitinduk
Aug 3, 2007 10:39 AM
