Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic LX (1.7L Auto) – No Lock-Up When Warm
Old Feb 6, 2026 | 04:23 PM
KennedyIrakoze's Avatar
Icon4 2005 Civic LX (1.7L Auto) – No Lock-Up When Warm
Hello everyone,
I’m looking for some insight from Honda techs or experienced owners.
Vehicle details:
• 2005 Honda Civic LX
• Sedan, 1.7L D17, Automatic
• Mileage: 165,216 miles
Symptoms:
• Transmission slips and does not lock into subsequent gears
• Operates normally when cold
• Once at operating temperature, slipping begins—worse at higher speeds
• No harsh engagement or bang shifts, just flare/slip
• No MIL currently
Work already performed:
• Drained and refilled ATF (used Castrol Transmax ATF/CVT Universal)
• Cleaned transmission solenoids (linear and shift solenoids)
• Fluid level verified hot and cold
Observations:
• Cold operation feels normal (good engagement, shifts OK)
• Heat appears to worsen the issue significantly
• Problem existed before fluid change and persists after
• No external leaks
  1. Could this be torque converter lock-up failure or linear solenoid degradation under heat?
  2. Are clutch packs (2nd/3rd) known to fail on high-mileage D17 automatics in this way?
  3. Would switching to Honda ATF-Z1 / DW-1 potentially change behavior, or is damage likely already present?
KeionL
Apr 8, 2021 12:17 AM
supergravi
Honda CR-V & Element
Aug 8, 2013 07:55 AM
mcd7
Oct 6, 2011 10:52 AM
Mak-90
11
Nov 28, 2010 10:15 AM
JMD
May 11, 2003 02:42 PM
