99 Civic Ex - Sometimes does not start...sometimes
Old Jan 19, 2026 | 01:26 PM
smetzger's Avatar
Default 99 Civic Ex - Sometimes does not start...sometimes
Car usually starts... but sometimes it will crank but not turn over.
I am thinking this is a coil pack issue. Last time it wouldn't start I put a hair dryer pointed at the distributor cap for 10 minutes and then the car started.
Thoughts?
Old Jan 20, 2026 | 06:27 AM
WesleyA's Avatar
Default Re: 99 Civic Ex - Sometimes does not start...sometimes
Have you checked all grounds?
Old Jan 20, 2026 | 09:48 AM
smetzger's Avatar
Not yet
Old Jan 22, 2026 | 03:46 PM
NVturbo's Avatar
O.G. triple O.G.
the internal ignitor in those distributors do go bad. I have like (3) ACCEL ignitors if you're interested. Will cut you a deal. PM me.
Old Jan 22, 2026 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Igniters or coils ?
Old Jan 23, 2026 | 02:38 PM
NVturbo's Avatar
O.G. triple O.G.
Originally Posted by JRCivic1
Igniters or coils ?
Accel Honda ignition coil 11076
Old Jan 23, 2026 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I am very familiar with the Accel replacement coils... you said "Igniter" in your post above and I wasn't aware that Accel made an ICM (Ignition Control Module or Igniter). I have used the coils with great success.
Old Jan 24, 2026 | 07:21 AM
diclemeg's Avatar
Thoughts?
Are you aware of the ECU capacitors issue? They get old and can't take up to 10 min the activate the fuel relay. Or a bad fuel relay. So you might think it started due to hair dryer...
Turn to ignition 1 if cel stays on more then 5 seconds then wait until it turns off...when it turns off you'll hear the the fuel pump behind you click too...then start.
Old Jan 25, 2026 | 10:00 AM
smetzger's Avatar
Ah... that sounds like it could be what is going on.
This is a new to me car...so need to learn it's foibles
Thanks
Old Jan 25, 2026 | 11:38 AM
JRCivic1's Avatar
10 Year Member
Community Builder
If you are experiencing the symptoms that diclemeg described, get the caps replaced right away. The longer you delay, the better chance that the ECU cannot be saved.
Old Jan 31, 2026 | 12:08 PM
smetzger's Avatar
are all the caps the same? if so, what values would i need?
Old Jan 31, 2026 | 07:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
No, there are FIVE different sizes/values. You can order capacitor kits from many different online sources.
Whtlightnin
Aug 31, 2018 10:42 AM
Mikes2000civicsi
Mar 12, 2010 10:29 AM
strangeyelp
Aug 16, 2007 10:20 AM
sharkey65a
Feb 23, 2004 03:08 PM
wizzards581
10
Jul 25, 2002 09:59 PM
