Injector Clip Retainer
Old Dec 27, 2025 | 08:25 PM
CWFL5CTR's Avatar
Default Injector Clip Retainer
I believe I have Prelude VTEC injectors in my car and I would like to get rid of these bootleg zip ties that hold down the clips. Does anyone know where I can get them? I'm assuming there is a metal clip that would secure it down? Just curious what are these clips called? (e.g. EV1?) The injectors are Keihin. Any info is appreciated!
Old Dec 27, 2025 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Injector Clip Retainer
I am not sure you can buy just the metal clips for your fuel injector plugs... you will likely have to purchase a set of the fuel injector plugs and simply rob the metal clips from them and place them on your current injector plugs. Remember that you will need the same type of plugs to get the clips from... OBD-0 style metal retaining clips are slightly different than those found on OBD-1 grey style plugs.
Old Dec 27, 2025 | 08:59 PM
CWFL5CTR's Avatar
This looks like it could work?
https://www.ebay.com/itm/389188216200
Old Dec 30, 2025 | 04:34 PM
CWFL5CTR's Avatar
I talked to the seller and sent him some more pics. Evidently I have an OBD0 plug. From reading old honda-tech posts from the previous previous owner, it should have Prelude injectors. I made the assumption it was from a 92+ Prelude, which should be OBD1/OBD2 no?
This is what I bought: https://www.ebay.com/itm/38912608729...torefresh=true
Old Dec 30, 2025 | 06:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Forget what year they are from... this does NOT dictate the OBD-X version. The plug style is milky clear in color, and this indicates an OBD-0 style. OBD-1 style injector clips are, with a couple of exceptions, grey in color. The link that you have referenced is one of those exceptions. Unfortunately, there is no photo of the BACK of the injector clips and how the metal retaining clip/lock is shaped. It MAY fit your current injector clips.
BoostinTEG
Jan 19, 2011 11:17 AM
kpjo4
Apr 15, 2010 10:15 AM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
