Re: coolant coming out of hole behind the vtec solenoid housing
Originally Posted by benchwarmer
Might be part of the system , Totally normal . If you had other major problems you'd know
Ummmm... no. Not normal. Coolant should not be coming out of any of the holes in the cylinder head where the VTEC assembly bolts up to it. These are all oil passages... if you have coolant there, it is mixing somewhere with the oil. It could be a cracked head, head gasket failure, etc.
