D16Y8 cyl 1 senser code
Need help need the car to run right it bogs down if you try to accelerate and has no power and there's a misfire intermittently but will idle fine scaner said cylinder 1 pos sensor how do I fix this issue can I rebuild the distributor Google says no that this sensor is in the distributor housing please help each is also all over the place
Airbag Club
11
Mar 10, 2005 03:05 PM
