Civid / Del Sol Alternator - Same For All Models?
Old Dec 1, 2025 | 09:59 AM
andrey320's Avatar
Default Civid / Del Sol Alternator - Same For All Models?
Are the D15 / D16 / B16 alternators all the same?
Old Dec 1, 2025 | 08:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Civid / Del Sol Alternator - Same For All Models?
The "D" series alternators are all similar (AMP output varies slightly due to power options), but the "B" series alternator is different - the mounting ears place the alternator too far back in the engine bay and the pulley makes contact with the frame rail.
Old Dec 2, 2025 | 06:25 AM
andrey320's Avatar
Thank you!
Old Dec 5, 2025 | 12:04 AM
3xhonfender's Avatar
I made a d17 work in my d16 the brackets were diff lengths belts I’d assume as well but I made it work nonetheless
Old Dec 5, 2025 | 03:42 AM
theYBLEGAL's Avatar
Loved
https://alternatorbrush.com/products...x0iEdHIWtM0Hf6
$40 make it like new for cheap cheap. It could be even cheaper if you search out the parts on ebay or individually source them.
I just fix mine anymore. Even take a spare rebuild kit to the track, its real easy to swap the diode components, usually the issue from my exp
94delsol6428
20
Oct 2, 2012 07:10 PM
CarGuy75
May 17, 2010 04:49 AM
RhdRicheeee
Dec 30, 2009 08:55 AM
hatchlover08
12
Mar 3, 2009 09:15 AM
