DIY VTEC controller?
Old Nov 19, 2002 | 04:42 PM
Qwikrex's Avatar
Default DIY VTEC controller?
I recently read an article on how to fabricate a custom VTEC controller using an RPM activated switch. Since I just had a CTR intake cam installed I wanted to raise the crossover point to 5700rpm. I know that I should get an AFC to augment fuel mapping as well, but for the mean time would it be ok just to raise the crossover until I can save enough for an AFC and dyno time? Would it hurt anything?
Old Nov 19, 2002 | 05:46 PM
chad's Avatar
Moderator
Default Re: DIY VTEC controller? ([VTEC]TL)
gonna cost you bout 150 for an MSD RPM activated switch and pills....plus they don't make a pill in the 5700 rmp range....
you might as well just get a vafc!
Old Nov 19, 2002 | 05:49 PM
Qwikrex's Avatar
Default Re: DIY VTEC controller? (Chad)
Found a RPM switch for $44. And it doesnt use pills. Adjustable from 2000-9800 rpm via dip switches and an adjustable ****.
[Modified by [VTEC]TL, 9:51 PM 11/19/2002]
Old Nov 19, 2002 | 06:00 PM
credditt's Avatar
Where did you find the $44 RPM switch?
Old Nov 19, 2002 | 07:25 PM
Qwikrex's Avatar
Default Re: DIY VTEC controller? (Fadi)
That was a pretty ghey and pointless pic.
Old Nov 19, 2002 | 07:58 PM
hungry's Avatar
i dont get it
do tell
Old Nov 19, 2002 | 08:25 PM
poison's Avatar
Default Re: DIY VTEC controller? (civic EHHH)
i dont get it
do tell
I hear that
Old Nov 25, 2002 | 09:13 AM
fuguman's Avatar
New User
share the source!!!!
Old Nov 25, 2002 | 09:26 AM
DaBuccaneer Fan
Guest
Posts: n/a
the hunt for bin laden continues...
Old Nov 25, 2002 | 10:45 AM
chad's Avatar
Moderator
Default Re: DIY VTEC controller? (DaBuccaneerFan)
it's a TYPE ARRRRRRRR tank
Old Nov 25, 2002 | 11:00 AM
tonyxcom's Avatar
how do you plan on adjusting your fuel curves that will almost make this a worthy mod?
Old Nov 25, 2002 | 11:02 AM
Airbag Club's Avatar
summit racing carries a lot of rpm activated switches.
civicjoe
16
Feb 25, 2008 01:57 PM
philkehn
10
Oct 3, 2006 11:55 AM
Lewdin' Incognito
Apr 11, 2005 10:20 AM
s2000june
16
Jan 31, 2004 06:55 PM
CLICC916
Sep 20, 2001 11:06 PM
