b18 crank in a b16?
got a b16 sleeved to 83mm, and i want to put a b18b or b18c1 crank in it to increase the displacement...but im not sure if my b16 crower rods will work with a different crank...
basically i dont know if the size of the crank would affect that situation...let me know
You wont be able to run your crower rods if you use the LS or GSR/ITR crank....you will have to use way shorter rods (not sure which ones, custom maybe) which will pretty much put your R/S ratio in the *******...it will make for a very unstable motor.
You could send your block to GEM and have them instal sleeves and a deck plate to acheive a better r/s raito...
The deck plate is a peice of thick peice of metal that is cut (or machined) to the exact shape of your deck (top of block), when you used a deck plate you have to have sleeves that are taller to accomidate the plate.
