Silicone Grease on Front LCA Bushings
Old Nov 24, 2025 | 06:44 AM
Grade50's Avatar
10 Year Member
Default Silicone Grease on Front LCA Bushings
The manual says to apply silicone grease to the two front LCA bushings but isn't really clear about where on the bushing. Do you think they're wanting to lube the joint between the inner metal collar of the bushing and the frame/fork metal? The manual really isn't clear. While the bolts get torqued down with the suspension loaded, I'm assuming Honda felt there would still be some rotation of these collars due to normal suspension travel?
mikzsan
Suspension & Brakes
10
May 8, 2017 01:03 AM
fryman
Nov 3, 2016 03:26 AM
bunga28
Suspension & Brakes
Nov 1, 2011 08:40 AM
TurboEM1
Suspension & Brakes
Dec 12, 2005 12:10 PM
CivicEK.PDX
Aug 13, 2002 06:52 PM
