Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Burns oil
Old Sep 17, 2025 | 02:04 AM
SaMaN88's Avatar
Default Burns oil
My 2013 2.4L accord burns a quart of oil every 1500miles. It has 85K. Is this normal?
Old Jan 15, 2026 | 06:12 PM
Major_Heat's Avatar
Default Re: Burns oil
no way, that’s way too much oil consumption for a Honda with only 85k miles, don't let anyone tell you that’s normal. It’s a known issue with these engines where the piston rings get gunked up, but you should definitely try swapping out the PCV Valve first. they are really cheap and can have a major impact to your problem it only takes minutes to change. best of luck. cheers
david61983
Nov 6, 2018 02:05 PM
cory_cinch
Jun 1, 2008 08:42 AM
sailor_55
Nov 4, 2007 09:14 PM
