Suspicious knock / tick
I have a 1989 EF sedan with the stock d15b2 and a pgmfi intake swap from a ‘91 integra. Since I’ve owned the car, it’s made this knock sound under engine acceleration. Here’s what I’ve done to it, related or unrelated to the issue:
owner said it was rebuilt 2k miles before I bought it, and I’ve put 10k on it and it’s never gone away. It’s worst when cold and almost goes away after being driven hard and fully warmed up. Sounds a little like an exhaust leak or very consistent pinging. I’ve unplugged the plug wires one by one and revved it, and it knocked each time. I don’t think it’s a connecting rod bearing or piston slap, but I haven’t borescoped it to check out the cylinder walls.
my next move would be plug wires or replacing that down pipe despite it looking newer. I may also take off the accessory belts to se if it’s a ps or alternator noise. After that I’ll just drive it till it blows up I guess. Let me know if you have a guess.
here’s a link to the video, if I get it to work without google drive I’ll edit the post:
https://drive.google.com/file/d/1J9pCY8C-zcj_Izghc_73rzM8Xxfs_CsH/view?usp=drivesdk
- Plugs
- valve lash
- Varying oil viscosities
- PCV valve
- throttle body gaskets
- IACV oring and clean out
- ignition timing
- swapped ECUs (same PM9 code)
- new exhaust system minus down pipe from header to flex pipe.
- various fuel octanes
- cant remember what else.
I set the valve lash to spec from the origenal honda shop manual. It may be an exhaust leak; I've replaced everything but the down pipe including all gaskets adjacent to said pipe. The sound is low, so its either that or what fear to be bottom end noise.
Fat Chick Magnet
Jan 18, 2008 08:12 AM
